Home > Tdi > an other smoky 300tdi |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 |
im no expert but i think black smoke is over fueling, or not enough air in the mix. My 109 thread
my youtube channel |
3rd Jul 2014 9:00am |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 |
Check your timing belt, Timing may be out causing to early or late injection.
Check your injector pump for signs someone has "tweeked" it and got it wrong. May be as simple as just resetting to factory settings. Is your turbo waste gate moveable? If its not closing then turbo isn't keeping up with fuel delivery and so the fuel is not being burnt. Have you checked your oil levels? if it is over full of oil can cause catastrophic failure as it can drink its own sump and you wont be able to stop it. Also do you have excessive turbo play? If so it could be pumping oil straight into the inlet and exhaust which will make smoke. |
3rd Jul 2014 4:58pm |
lacrits68 Member Since: 23 Apr 2014 Location: Umeå Posts: 9 |
now i have...! case closed? |
3rd Jul 2014 5:09pm |
Afraid so.
3rd Jul 2014 5:49pm |
Diablo Member Since: 26 Oct 2011 Location: Basingstoke Posts: 335 |
Get it sorted soon as.
My turbo went very suddenly a year or so back, dumping all the oil down the exhaust in a matter of seconds and ended up with this: Click image to enlarge |
3rd Jul 2014 6:30pm |
hello!
I will...its probably gona be one of these kits ( nr1 kit) http://www.mdengineering.co.uk/pdf/112~TGV...%20Tdi.pdf Click image to enlarge Click image to enlarge Click image to enlarge cheers Jan |
4th Jul 2014 4:58am |
^^^nice My 109 thread
8th Jul 2014 5:06pm |
problem solved...new (actualy 2nd hand) turbo, new de cat downpipe, egr blanked, new injectors and timing checked and adjusted...!
Goes lite a recer and is nowdays an "non smoker" thans all! //Jan Last edited by lacrits68 on 3rd Aug 2014 9:33pm. Edited 1 time in total |
3rd Aug 2014 9:09pm |
Good to Hear
3rd Aug 2014 9:20pm |
