Home > Puma (Tdci) > Fitting an indicator light to show DPF regen? |
Natlas Member Since: 20 Mar 2013 Location: West Sussex Posts: 460 |
This would be a popular mod if available. 2.2 90 XS
88" Series One Old Norton Minerva |
6th Jul 2014 10:09pm |
borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677 |
I dont have a wiring diagram to see where to take off the LED from. It cant be that difficult. At least you could continue the regen until its finished. Thinking about it, the light would need to be on throughout regen so you know how long to continue.
6th Jul 2014 10:21pm |
Come on Mr Bell, can you make my idea come to life?
6th Jul 2014 10:28pm |
pob1968 Member Since: 20 Apr 2014 Location: uk Posts: 239 |
I would be keen to do this mod too, I do a lot of short trips so if it starts "regenning" I can see to carry on driving a little while longer to allow it to finish. 110 Hardtop
7th Jul 2014 7:42am |
Schw8te Member Since: 03 Jun 2012 Location: NRW Posts: 27 |
Yes, I would like this LED too.
Yesterday my dpf-regeneration startet and the boost pressure (scangaugeII) dropped to 0,2bar at 2400rpm on 4th gear and -0,7 bar on idle. It took 20km on the Autobahn to finish the reg = the boost pressure raises to normal. A LED indicator would be very helpful as it ist much easier to check than the boost pressure reading. Cheers Det locker bleiben |
7th Jul 2014 7:55am |
Come on the tuning fraternity, any thoughts?
10th Jul 2014 2:10pm |
adamatdraycott Member Since: 11 Nov 2013 Location: Midlands Posts: 299 |
Is there any way other than a light to tell if it's on a regen? Noise or smell maybe?
10th Jul 2014 8:51pm |
Too many noises in a Defender! Too many smells sometimes too! A light is what we need. Mr Bell must have an answer?
10th Jul 2014 9:01pm |
milesr3 Member Since: 12 Feb 2013 Location: Suffolk Posts: 873 |
I used to be able to tell that my BMW 535D was doing a regen, but I have never noticed the Defender doing it until getting out and hearing the exhaust ticking (and then burning my hand on it). Did once feel the heat coming through the footwell on a long journey. Whilst in some ways it would be good to know, in other ways it's great that you don't have to.
The Defender does seem quite capable of keeping the DPF clean, by frequent active regens at low speeds. Quite unlike a lot of mainstream cars, but probably at the expense of fuel economy. There is always the amber DPF warning light on the dash if the regen cycle has not been successfully completed and the vehicle needs to be driven until it does |
10th Jul 2014 10:22pm |
Mjibex Member Since: 21 Mar 2013 Location: Reading Posts: 283 |
The standard light indicates that the filter is almost full, not that 1 regen has not completed.
I don't know how many attempted regens can happen before the standard light would come on. The point of this indicator being discussed would be if the light comes on - keep driving till it goes off. The idea being that incomplete regens contaminate the oil with diesel. |
10th Jul 2014 10:47pm |
I would be interested in this also.
10th Jul 2014 10:48pm |
That's the idea! |
10th Jul 2014 10:56pm |
Alive Tuning Member Since: 01 Mar 2010 Location: Louth Posts: 609 |
I spent half an hour last night going through the code, looking to see if there was a simple switch that could be set to allow a visible warning that regen was taking place. There are regen abort procedures within the code for when the engine is shutdown, so its all taken care of. There are a couple of areas of interest, that I'll do some tests on (when I get time!) to see if this could be done.
11th Jul 2014 4:11pm |
That's excellent! Thanks for taking the time to look into it for us
11th Jul 2014 4:59pm |
