Home > Puma (Tdci) > Fitting an indicator light to show DPF regen?
If it were possible, who would like to have an indicator light which tells you when the DPF regen is taking place?
Yes please
90%
 90%  [9]
No thanks
10%
 10%  [1]
Total Votes: 10
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
Given the potential for switching off mid regen and the associated problems this causes, I was wondering if it would be possible to fit a LED into the dash showing when the process has started or is occurring? If it is possible where would I take off the signal for the LED?
Post #343183 6th Jul 2014 2:15pm
Natlas
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Aintree Green
This would be a popular mod if available. Thumbs Up 2.2 90 XS
88" Series One
Old Norton Smile
Minerva
Post #343284 6th Jul 2014 10:09pm
borderterrier
I dont have a wiring diagram to see where to take off the LED from. It cant be that difficult. At least you could continue the regen until its finished. Thinking about it, the light would need to be on throughout regen so you know how long to continue.
Post #343288 6th Jul 2014 10:21pm
borderterrier
Come on Mr Bell, can you make my idea come to life? Very Happy
Post #343290 6th Jul 2014 10:28pm
pob1968
I would be keen to do this mod too, I do a lot of short trips so if it starts "regenning" I can see to carry on driving a little while longer to allow it to finish. 110 Hardtop
Post #343329 7th Jul 2014 7:42am
Schw8te
Germany 2013 Defender 90 Puma 2.2 SW Santorini Black
Yes, I would like this LED too.
Yesterday my dpf-regeneration startet and the boost pressure (scangaugeII) dropped to 0,2bar at 2400rpm on 4th gear and -0,7 bar on idle. It took 20km on the Autobahn to finish the reg = the boost pressure raises to normal.
A LED indicator would be very helpful as it ist much easier to check than the boost pressure reading.
Det locker bleiben
Post #343333 7th Jul 2014 7:55am
borderterrier
Come on the tuning fraternity, any thoughts?
Post #344244 10th Jul 2014 2:10pm
adamatdraycott
United Kingdom 2014 Defender 90 Puma 2.2 SW Corris Grey
Is there any way other than a light to tell if it's on a regen? Noise or smell maybe?
Post #344327 10th Jul 2014 8:51pm
borderterrier
Too many noises in a Defender! Too many smells sometimes too! A light is what we need. Mr Bell must have an answer?
Post #344334 10th Jul 2014 9:01pm
milesr3
2016 Defender 90 Puma 2.2 XS CSW Keswick Green
I used to be able to tell that my BMW 535D was doing a regen, but I have never noticed the Defender doing it until getting out and hearing the exhaust ticking (and then burning my hand on it). Did once feel the heat coming through the footwell on a long journey. Whilst in some ways it would be good to know, in other ways it's great that you don't have to.
The Defender does seem quite capable of keeping the DPF clean, by frequent active regens at low speeds. Quite unlike a lot of mainstream cars, but probably at the expense of fuel economy.
There is always the amber DPF warning light on the dash if the regen cycle has not been successfully completed and the vehicle needs to be driven until it does Thumbs Up
Post #344370 10th Jul 2014 10:22pm
Mjibex
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Loire Blue
The standard light indicates that the filter is almost full, not that 1 regen has not completed.
I don't know how many attempted regens can happen before the standard light would come on.
The point of this indicator being discussed would be if the light comes on - keep driving till it goes off.
The idea being that incomplete regens contaminate the oil with diesel.
Post #344383 10th Jul 2014 10:47pm
Mjibex
I would be interested in this also.
Post #344384 10th Jul 2014 10:48pm
borderterrier
That's the idea!
Post #344388 10th Jul 2014 10:56pm
Alive Tuning
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Havana
I spent half an hour last night going through the code, looking to see if there was a simple switch that could be set to allow a visible warning that regen was taking place. There are regen abort procedures within the code for when the engine is shutdown, so its all taken care of. There are a couple of areas of interest, that I'll do some tests on (when I get time!) to see if this could be done.
Post #344541 11th Jul 2014 4:11pm
borderterrier
That's excellent! Thanks for taking the time to look into it for us Very Happy
Post #344549 11th Jul 2014 4:59pm
