Home > Puma (Tdci) > Fitting an indicator light to show DPF regen?
If it were possible, who would like to have an indicator light which tells you when the DPF regen is taking place?
Yes please
90%
 90%  [9]
No thanks
10%
 10%  [1]
Total Votes: 10
Page 2 of 2 <12
milesr3
2016 Defender 90 Puma 2.2 XS CSW Keswick Green
Mjibex wrote:
The standard light indicates that the filter is almost full, not that 1 regen has not completed.
Didn't say it was. The amber light means that the DPF is nearly full, due to not successfully regenerating by active and passive means. This is the only time you really do need to keep driving until the light is extinguished.
Whilst it makes sense to keep driving if you're in the middle of an active regen you don't have to. The ECU will request regeneration next time the conditions for regeneration are met.
The workshop manual says that regeneration typically occurs every 250 miles, which is very frequent and one of the reasons fuel economy is not great. The DPF is also massive and right on the exhaust manifold, so it's likely that passive regeneration is going to keep it pretty clean.
How many problems have there been with blocked DPFs or oil dilution with Defenders?
Post #344675 12th Jul 2014 9:51am
bell-auto-services
Re alight, though I appreciate their can be many varients of trying to add a light to the car its probabally possibile that you can pick up from the CAN one of its messgaes for either the DPF or EGR postion during the dpf regen cycle. Inject that into a CAN node and re out put it to flash the mil lightevery 1 second during a regen or simlar.
Or limit torque or rpm during a regen so the driver will feel that its doing a regen, many many ways but all take time i think for possibily little gain to the car overall.
Regards Pete
Post #344679 12th Jul 2014 9:57am
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
Looks like my hopes rest with Alive Tuning!
Post #344682 12th Jul 2014 10:43am
bell-auto-services
Their as Alive said is not a lot in the engine ecu that is related to the dpf and lamp enablement especially for out putting it to a seperate lamp of the car so id assume without looking further and deeper it will be to be some in the middle compremise of notification somehow for the driver.
Pete
Post #344691 12th Jul 2014 11:26am
borderterrier
Thanks Pete
Post #344695 12th Jul 2014 12:01pm
Mynstral
United Kingdom 2015 Defender 110 Puma 2.2 USW Montalcino Red
Hi all. Been having a think on this. Is it something a Scangage could be programmed to monitor?
Regards Myn. Smoke me a kipper I'll be back for breakfast.
Post #348180 29th Jul 2014 9:08am
borderterrier
Dunno. I just want a simple LED in the dash to tell me.
Post #348182 29th Jul 2014 9:19am
pob1968
Daft as it sounds could the power that feeds the DPF itself be just tapped into to supply a positive to a LED? I am an auto electrical numpty by the way - haven't got a clue but would like to have the light telling me if it's possible. 110 Hardtop
Post #348196 29th Jul 2014 10:26am
borderterrier
That's what I was thinking too. No know nothing about 'code', a bit of solder and a LED is my limit!
Post #348205 29th Jul 2014 11:11am
Mjibex
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Loire Blue
Or if not as simple as above - a temperature sensor of some sort - the temperature rise should be enough (above a certain temperature) to be indicative of attempted regen.
Post #348244 29th Jul 2014 4:26pm
Juhulia
2012 Defender 110 Puma 2.2 SW Keswick Green
A ctrl light would be great for longer off-road trips.
Most of the short distance pilots are presumably animated to start collecting bonus miles Very Happy
I suppose that shorter oil change intervals are the best idea for futher investments into that "DPF thing". Idea
But I must say that after about 15k km there have not been any issues with that DPF. I suppose it would be clever to clean the DPF with grill cleaner after about 50k km, wouldn't it? Thumbs Up Milestone Milestone
Post #349060 2nd Aug 2014 6:37pm
Page 2 of 2 <12
