Home > Puma (Tdci) > caterhams LAST problem! |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6300 |
fantastic.....your feeling towards your truck and mine towards mine are like polar opposites.
have a great time and let me know if you can find any loop holes in the system for getting immigrants into Oz the UK has gone down the pan so far as I'm concerned (please note all this is a personal opinion and not something any of us need to start a debate on - apologies if this either upsets or causes disagreement with anyone) was going to say have a nice day but I guess you're getting ready for bed? |
7th Jul 2014 8:03am |
[quote="Caterham"]I do some times wonder if what my dad keeps saying holds any water so to speak and that I shouldn't jetwash under the bonnet but I keeping saying these things are indestructible.
yes your dad is right your defender will give more problems and rot more think about it this way , your fairly waterproof yourself you can swim underwater but let yourself be jetwashed and see if it enters any of your orifices ! |
7th Jul 2014 8:14am |
sorry was in a jovial mood
no jet washing.......at all.......and certainly not under the bonnet albeit it does get sprayed with water but only by hand. |
7th Jul 2014 8:17am |
Group buy anyone? 'Caterham's Off To Oz' campaign starts right here: We'd probably get Charity Status? If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 7th Jul 2014 8:20am. Edited 1 time in total |
7th Jul 2014 8:18am |
ok good
this answer was ment for the jetwashing post next above but one but can go for one above as well |
7th Jul 2014 8:19am |
ever get the feeling you're not wanted? |
7th Jul 2014 8:35am |
Love you Caterham! Not in a gay way but a blokey type way!
XX Better now? Before you start another one! Thread that is! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
7th Jul 2014 8:41am |
feeling is mutual, that is not in a gay or man / sheep way just a buddy / mate type man thing I'm still looking forward to my next trip to the south coast to 'compare notes' - you'll hear me coming now with my new sub woofer install ! talking of new threads...... I'm not worried at all about this just an observation / concern. does your water temp stay constant? I though mine was always smack bang on 90. I've now noticed it swings between c86 - 93 which I would kind of expect with thermostat opening / closing etc and temps well within in range but just a little surprised as I thought it always stayed steady? |
7th Jul 2014 8:50am |
The water temperature does indeed vary. Please read the following and inwardly digest.....
YOU HAVE NOTHING TO WORRY ABOUT AND YOUR COOLANT SYSTEM APPEARS FULLY-FUNCTIONAL AND NORMAL. DO NOT TINKER WITH IT, TOUCH IT, OR EVEN GIVE IT A PASSING GLANCE OR FURTHER THOUGHT. PUT IT TO THE VERY REAR STORE ROOM OF YOUR MIND. (THE DUSTY BIT WHERE NOBODY GOES) AND FORGET ABOUT IT! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
7th Jul 2014 8:55am |
done. !
7th Jul 2014 9:00am |
Thank you so much! If you go through life with your head in the sand....all people will see is an ar5e!!
7th Jul 2014 10:00am |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3471 |
Good to hear you are not falling into the trap of needlessly worrying and bothering others about issues or bits of your Defender that may or may not be waiting to catch you out or fall off Caterham
BTW: I opened my drivers window while my Defender was in motion today and could not help noticing that I could no longer hear the radio clearly. Does this mean there is something wrong with the vehicle or have I just become a deafol'git too? Steve. Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
7th Jul 2014 12:17pm |
I suspect you either have a faulty hand brake, glass or blockage in the air intake.
On occasion I have a similar intermittent fault which I've yet to nail. If I were you I should investigate all 3 possible causes and hopefully this will lead to other avenues of possible concern which you can investigate. Whichever route you take be sure to swap over a few sensors along the way to help empty your pockets and line Land Rovers - the more sensors you are able to replace the greater the carma effect. good luck - you may need it. |
7th Jul 2014 12:34pm |
AlanH Member Since: 15 Mar 2010 Location: WA Posts: 242 |
I've found the very best way to continue liking the Deafener is to not open the windows and never ever to wear my hearing aids.
Silence is golden as some one once said. AlanH. |
10th Jul 2014 9:12am |
