![]() | Home > Tdi > Semi Synthetic 15/40's engine oil in gearbox |
if you put a bit thicker oil which engine oil would be it will be a real pig to get 2nd gear when cold ,
think yours would use atf in the box , I would try one of the modern thin gear oils , mtf94 maybe |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 ![]() ![]() ![]() |
Use MTF94.
The Haynes book of suggestions advise ATF but as I found out it runs too hot and boils in the box. Land Rover found that out too and worked with oil companies to make MTF94 (or so I'm told) and from about 1990 onwards only used MTF94 in there boxes. The crunching is going into second is due to warn syncromesh gears which is common for your box. Changing to MTF94 will improve it, take your time with gear shifts to allow the syncro to work will help. Unfortunately it will only ultimately be cured by a gearbox change/rebuild. |
cornish rattler Member Since: 31 Aug 2013 Location: Manchester Posts: 642 ![]() ![]() ![]() |
Yeah i may look into a recon'd box at a later date.
where is the best place to buy this oil you specify ![]() 1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
Give opieoils - site sponsor a ring they will probably have it on the shelf and give you a forum discount.
Last batch I got was from ebay, think its was �9 a litre. From memory needed 4 litres as you always spill some and then you have some spare for topping up ![]() |
Nice one shaggy i will buy some but it mite be after billing now so will keep the speed down abit to help the gearbox as i only changed the oil ( A.T.F. ) last month
