Home > Tdi > Semi Synthetic 15/40's engine oil in gearbox
cornish rattler
United Kingdom 1988 Defender 90 200 Tdi CSW Bronze Green
Hi guys
Again got talking to a wagon driver at work yesterday about landies as he owns a 300tdi disco and got talking about my gearbox just starting to crunch in gear when going into secon'd gear and i know his gearbox is different to mine but he said he runs his gearbox on 15/40's semi synthetic engine oil and just wondered if I can run my gearbox on the same oil
1988 90 2.5td ( 200tdi ) with L77 gearbox Smile Graham
1988 Defender 90 county 200tdi ( Beast )
Paul Walker 1973-2013
( I Almost Had You )
Post #341740 30th Jun 2014 8:22am
munch90
if you put a bit thicker oil which engine oil would be it will be a real pig to get 2nd gear when cold ,
think yours would use atf in the box , I would try one of the modern thin gear oils , mtf94 maybe
Post #341752 30th Jun 2014 9:27am
shaggydog
Use MTF94.
The Haynes book of suggestions advise ATF but as I found out it runs too hot and boils in the box.
Land Rover found that out too and worked with oil companies to make MTF94 (or so I'm told) and from about 1990 onwards only used MTF94 in there boxes.
The crunching is going into second is due to warn syncromesh gears which is common for your box.
Changing to MTF94 will improve it, take your time with gear shifts to allow the syncro to work will help. Unfortunately it will only ultimately be cured by a gearbox change/rebuild.
Post #341857 30th Jun 2014 6:09pm
cornish rattler
Yeah i may look into a recon'd box at a later date.
where is the best place to buy this oil you specify Smile Graham
Post #342179 2nd Jul 2014 12:57am
shaggydog
Give opieoils - site sponsor a ring they will probably have it on the shelf and give you a forum discount.
Last batch I got was from ebay, think its was £9 a litre. From memory needed 4 litres as you always spill some and then you have some spare for topping up Thumbs Up
Post #342304 2nd Jul 2014 6:35pm
cornish rattler
Nice one shaggy i will buy some but it mite be after billing now so will keep the speed down abit to help the gearbox as i only changed the oil ( A.T.F. ) last month Smile Graham
Post #342391 3rd Jul 2014 12:28am
