Home > Puma (Tdci) > new 2.2Tdci without fuel-cooler (?)
landybehr
A guy on the blacklandy.de - forum got aware of a fuel cooler missing on his rather new Defender. There ist just a bent piece of tube.
I came across an obviously very new 110" this weekend (4x4 exhibition) and this one also had just a tube. Another 110" with slightly worn brake discs but new-looking still had the cooler (as has my spring-2012-registered 110" 2.2).
In case itīs not been discussed - what was the time this was changed, and are there any other changes that came with the newest engines (injection system). Or can any 2.2 omit the cooler and put in that "tube" instead ???
Post #339964 22nd Jun 2014 10:52pm
jomara
Scotland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
On my 2nd 2.2, first was 2013 model latest 2014 model no fuel cooler on either!! Don't think it exists on the new engine, but I may be wrong!! 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto
2022 110 250D XS
Post #339967 22nd Jun 2014 11:11pm
psimpson7
Australia 2014 Defender 90 Puma 2.2 XS CSW Loire Blue
pic from my Jan 2014 build. Aus spec so some differences including no DPF:
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  2001 90 HT 6.0LS/6spdAuto.
2003 90 td5 soft top.
2014 90 XS SW 2.2.
Post #339981 23rd Jun 2014 2:09am
Schw8te
Germany 2013 Defender 90 Puma 2.2 SW Santorini Black
Hey, look at oilfilter! My 2013 got this plastic bowl, seems they made a few changes...
Det locker bleiben
Post #339988 23rd Jun 2014 7:18am
Those fuel cooler pipes are surprisingly expensive if damaged, will leave you stranded too if they get damaged and leak.
Post #340058 23rd Jun 2014 12:13pm
munch90
more cost cutting ?
Post #340061 23rd Jun 2014 12:22pm
Killer90
Site Sponsor
Its found up the side of the engine now last time i checked, there prone to damage down below so a fuel cooler guard is a very good idea. Thumbs Up even on 2.2's were the fuel cooler is up higher you can still fit the guards to protect the fuel lines Mr. Green CSK Automotive
www.cskautomotive.co.uk
Post #340063 23rd Jun 2014 12:31pm
psimpson7
Killer, that pic I posted is of my 2014 2.2
is yours different? 2001 90 HT 6.0LS/6spdAuto.
2014 90 XS SW 2.2.
Post #340067 23rd Jun 2014 12:45pm
Killer90
Site Sponsor
Yer can not see them on uk spec i assume. I have 2 brand new 14my defenders in at the moment and my own both are not visible underneath Thumbs Up i have a early 2.2 in aswell so will have a check Mr. Green CSK Automotive
Post #340082 23rd Jun 2014 1:47pm
psimpson7
Interesting! so over here we keep the fuel cooler, but don't have the DPF! 2001 90 HT 6.0LS/6spdAuto.
2014 90 XS SW 2.2.
Post #340263 23rd Jun 2014 9:23pm
x-isle
Straight from D4x4 website about their cooler guard;
"The 2.2 Tdci Defender does not have a fuel cooler but does have a exposed oil pipe where the 2.4's cooler would be fitted. We are fitting these guards to 2.2's to protect the oil pipe for damage as you can see in the images." Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #342699 4th Jul 2014 8:27am
jst
i had one of these guards on the shelf in the wksp for ages. was debating whether to fit it or not.
then my fuel lines were ripped out of the cooler whilst crossing some brush..............
typical
its was soon fitted with the new pipes....
(2.4 10MY) Cheers
James
110 XS Utility
130 Puma Station wagon/camper (in the making)
90 Puma Hardtop
Post #342908 4th Jul 2014 10:45pm
Well mine's definitely a MY13, 2.2 and DPF and does have a fuel cooler fitted. So if a change was made it must have been made after a certain VIN number.
Post #343418 7th Jul 2014 12:01pm
Taff
2012 Defender 90 Puma 2.2 HT Indus Silver
I had. March 2012 2.2 and it had the Cooler, DPF and plastic oil filter bowl and paper element.
Taff
Post #346280 19th Jul 2014 3:55pm
