![]() | Home > Puma (Tdci) > new 2.2Tdci without fuel-cooler (?) |
jomara Member Since: 26 Oct 2009 Location: Lanarkshire Posts: 1774 ![]() ![]() ![]() |
On my 2nd 2.2, first was 2013 model latest 2014 model no fuel cooler on either!! Don't think it exists on the new engine, but I may be wrong!! 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 250D XS |
psimpson7 Member Since: 20 Nov 2013 Location: Gold Coast, Qld. Posts: 221 ![]() ![]() ![]() |
pic from my Jan 2014 build. Aus spec so some differences including no DPF:
![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() 2003 90 td5 soft top. 2014 90 XS SW 2.2. |
Schw8te Member Since: 03 Jun 2012 Location: NRW Posts: 27 ![]() ![]() ![]() |
Hey, look at oilfilter! My 2013 got this plastic bowl, seems they made a few changes...
Det locker bleiben |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19803 ![]() ![]() |
Those fuel cooler pipes are surprisingly expensive if damaged, will leave you stranded too if they get damaged and leak.
more cost cutting ?
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 ![]() ![]() ![]() |
Its found up the side of the engine now last time i checked, there prone to damage down below so a fuel cooler guard is a very good idea.
![]() ![]() www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
Killer, that pic I posted is of my 2014 2.2
is yours different? 2001 90 HT 6.0LS/6spdAuto. 2003 90 td5 soft top. 2014 90 XS SW 2.2. |
Yer can not see them on uk spec i assume. I have 2 brand new 14my defenders in at the moment and my own both are not visible underneath
Interesting! so over here we keep the fuel cooler, but don't have the DPF! 2001 90 HT 6.0LS/6spdAuto.
x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327 ![]() ![]() ![]() |
Straight from D4x4 website about their cooler guard;
"The 2.2 Tdci Defender does not have a fuel cooler but does have a exposed oil pipe where the 2.4's cooler would be fitted. We are fitting these guards to 2.2's to protect the oil pipe for damage as you can see in the images." Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7773 ![]() ![]() |
i had one of these guards on the shelf in the wksp for ages. was debating whether to fit it or not.
then my fuel lines were ripped out of the cooler whilst crossing some brush.............. typical its was soon fitted with the new pipes.... (2.4 10MY) Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
Well mine's definitely a MY13, 2.2 and DPF and does have a fuel cooler fitted. So if a change was made it must have been made after a certain VIN number. |
Taff Member Since: 28 Dec 2012 Location: Bath Posts: 16 ![]() ![]() |
I had. March 2012 2.2 and it had the Cooler, DPF and plastic oil filter bowl and paper element.
Taff |
