Home > Puma (Tdci) > terrible clatter then no power SOLVED |
bga86 Member Since: 17 Jan 2014 Location: Here and there Posts: 205 |
Sounds like diesel knock, could be a faulty fuel metering valve/rail pressure sensor. Best thing to do is get the fault codes read first, clutching at straws until you do that really
19th Jun 2014 7:16pm |
martinfiattech Member Since: 13 Nov 2013 Location: leicester Posts: 422 |
Along with that I would get the injectors tested or at least get the return flow from the injectors measured, you never know it might save a bent con rod. Excuse the spelling I`am better with spanners and wires.
19th Jun 2014 8:49pm |
1989964 Member Since: 11 May 2014 Location: cheltenham Posts: 57 |
thanks for the replies, from further reading i think the clattering noise on a light throttle could definately detonation from over fuelling. Thats why when i floor the throttle the noise disappears ( correct fuel /air ratio) and on a completely closed throttle the noise disappears. just need to find the reason. im thinking the metering valve on the injector pump??? or the MAF or the MAP. Any other ideas guys. thankyou
19th Jun 2014 9:10pm |
I will get the codes read and report back
19th Jun 2014 9:11pm |
there were no codes stored. the fuel rail pressure was between 3500 and 8000 psi when revved and the MAP was at 100 kPa. does this sound right?
21st Jun 2014 4:25pm |
fuel rail pressure on common rail should be a lot lot higher
are you sure that it was psi ? does it black smoke when it plays up ? Last edited by munch90 on 21st Jun 2014 4:41pm. Edited 1 time in total |
21st Jun 2014 4:36pm |
yes i think so it was 3000 at tickover and rose to about 7500 at 2000rpm, that is about 500 bar.
21st Jun 2014 4:37pm |
land rover manual states 1600bar so about 23,000psi
21st Jun 2014 4:43pm |
thanks i'll double check it tomorrow.
21st Jun 2014 6:00pm |
hi, yes it maxed out at 1600 mPa on the fuel rail. the MAP seemed to go up as the turbo did and peaked at 240 kPa, 100 on tickover. no fault codes were found.
22nd Jun 2014 3:32pm |
something still not right
1600mpa is 232,000 psi 160mpa is 23,000 psi (so about right ) 160mpa is 1600 bar how often does it do it? Last edited by munch90 on 22nd Jun 2014 4:07pm. Edited 1 time in total |
22nd Jun 2014 3:58pm |
im fairly sure its just a decimal place out as otherwise it would either blow the relief valve or not work at all. And its 1600 which is what the rail is supposed to run at. im stumped, i think it might be bad engine noise after all. fluids are fine, engine temp is fine, 91c and no vacuum in the fuel tank.
22nd Jun 2014 4:02pm |
do a search on web for transit 2.4 tdci engine clatter may find answer or help
22nd Jun 2014 4:09pm |
Have you removed the fuel relief valve to check it hasn't popped?
22nd Jun 2014 4:21pm |
