Home > Puma (Tdci) > terrible clatter then no power SOLVED
Page 4 of 5 <12345>
In my case, the most noticeable symptom is that the engine hunts slightly when not fully warm. If you are slowing down in traqffic, you can feel it lurching very slightly. There is no MIL, and there will be the "pump learn not carried out or not complete" error, I can't offhand remember the code.
If you clear the fault and recalibrate the VCV the vehicle runs better (smoother) again, for 4 to 8 weeks, then it happens all over again! Very strange.
It only started doing this after I replaced the VCV, though, so I do wonder if the replacement valve is not wholly behaving itself. It is a more appetising diagnosis than a faulty ECU!
Post #345290 15th Jul 2014 7:26am
bell-auto-services
The VCV amongts other things can cause many running problems from rough idle, to noisy sounding injection to the engine not starting at all.
As seen they are easy to fit but do need coding in after being fitted, in some cases the old one can be re learned and it can help with running issues. I do advise when doing the learn that the engine is hot.
We have found some old valves will not code in correctly until the engine is really really hot and from that we found eveutually they fail so this could be an early indication they are failing ?
Post #345302 15th Jul 2014 9:33am
Yes, I did think that my symptoms may be those of a defective valve, despite being brand new less than a year ago from a Ford dealer!
Erratic running but with no fault codes generally seems symptomatic on the Puma of a VCV fault. Most other fuel system issues seem to generate DTCs, at least on the HP side.
Post #345322 15th Jul 2014 11:33am
1989964
United Kingdom 2001 Defender 90 Td5 SW Alveston Red
so Pete, i guess i should do the vcv swap with a cold engine then run it up to really hot then code it? rather than do the exchange with a piping hot engine??
thankyou
Post #345404 15th Jul 2014 4:33pm
1989964
oh well that was a waste, changed the vcv, went for a thrash to get it hot then tried to learn pilot,,, same result, 0x50 failed. When i removed the inlet manifold to gain access
I did see that the engine was extremely oily and cokey in the inlet manifold and inlet ports, this is likely what is stopping the turbo actuator arm from having full range and giving the idle dynamic turbo test fail. guess this could also cause a fail in the pilot learn???
I am thinking seriuosly of getting a terraclean, its 110 quid and should help with the turbo and injectors. i will report back. see photos for carbonisation
any other suggestions gratefully received
Post #345602 16th Jul 2014 3:41pm
munch90
that's not as bad as some ive seen
good ole egr valves
maybe be good for lowering emissions but this this what you get !
amazing when you think how fussy people are about servicing they cars , replacing air filter when you got the egr putting all this cr@p in your engine
Post #345623 16th Jul 2014 5:36pm
1989964
Yes on the way to the pub i was trying to fathom how it got so bad as it should be fresh air and figured it must be turbo oil seals but of course its EGR. crap.
Post #345630 16th Jul 2014 6:25pm
1989964
btw my engine software is 7H12-12K532-FDD is this the latest one does anyone know? thanks
Post #345790 17th Jul 2014 11:21am
1989964
Thanks
Post #345895 17th Jul 2014 7:20pm
1989964
Had Terraclean. Maybe engine is a little quieter, probably just wishful thinking.
Tried to do another pilot learn, failed with a 0x58 message, adjustments too extreme or somesuch then another fail 0x50 as before, in start mode or something.
did another dynamic turbo air pipe test, failed again at idle test, actuator arm not moving as expected or something like that.
I hope someone is gaining something from this info as I am almost at the point of dumping the car altogether. Am going to order a bottle of forte turbo clean and run that through to try to eliminate the air test fail, Get car saleable then sell it. Having read all the relevant transit posts as well as the defender posts it seems this engine is extremely prone to fuelling issues with a multitude of possible causes and fixes. JLR SDD has not impressed me either, coming from BMW ISIS.
Post #345898 17th Jul 2014 7:28pm
1989964
Thought I'd let everyone now the outcome. after the terraclean I ran a bottle of Forte diesel turbo cleaner in 35 litres of fuel. This improved the sound somewhat but the clatter was still there.
I was then able to successfully do a "pilot learn" in SDS, something that was not possible before.
The engine note changed and the clatter was gone. The engine now sounds exactly as it should and i consider the problem solved.
Hopefully this post helps others.
Post #351583 14th Aug 2014 3:20pm
landy andy
Thumbs Up Thumbs Up
Good for you, hope it remains sorted.
Andy
Post #351703 15th Aug 2014 5:15am
landy andy
Is this all good now? Think I've got a similar knock noise
Andy
Post #365742 19th Oct 2014 7:39pm
1989964
yes its still running as it should, the pilot learn cured the terrible rattle.
Post #365811 20th Oct 2014 6:36am
1989964
in other words i think the turbo cleaner did clean the vanes inside the turbo and the induction side of the engine so that the computer "saw" the engine running within limits and then allowed the pilot learn to take place. prior to the forte turbo cleaner and/or the VCV replacement the engine was so "dirty/ out of spec" the software would not allow the pilot learn to take place.
Post #365813 20th Oct 2014 6:40am
Page 4 of 5 <12345>
