Home > Puma (Tdci) > HELP PLEASE! Prop shaft, clunk, play
Page 1 of 4 1234>
Cheshire110
the 110 has recently been clunking A LOT and it seems to be getting worse. Used to just be on bad gear changes but happens a lot more now.
Got under the car (wheels on the ground, so no turning them) and felt the front prop shaft. It spins a lot(80-90 degrees?) (not play in the UJs, but the shaft actually turning in both the the diff end and the transfer box end.
I've attached a video of the prop shaft and the noise that i get when driving around:
http://s1340.photobucket.com/user/davidwhi...e.mp4.html
What could be the problem? The rear has only a few degrees of play which seems fine but the front is really very bad it seems.
Thanks in advance guys Cheers, David
Post #338841 17th Jun 2014 8:52pm
Braydog
Australia 2008 Defender 110 Puma 2.4 SW Alpine White
Had similar concerns with mine, lots of propshaft play and a sinister clunk on gear changes, especially under load. Anyway ended up being a broken front diff. Replaced the diff with a Detroit truetrac and it drives like new again.
All the best with diagnosing your problem. Sometimes It is better to ask for forgiveness, than to ask for permission.
Post #338889 18th Jun 2014 1:37am
LR90XS2011
David
Bad news I think mate, looks like a knackered diff to me, speak to Ashcroft, loads of threads on here re front diff woes, don't drive it more than you need to, if it fails it could cause an accident and/or more damage!!
have you got a warranty?
Also were you not about to do a service, the oil coming out will probably contain evidence of failure DEFENDER 90 TDCI XS,
Post #338892 18th Jun 2014 5:16am
landy andy
What age is it? If before 10 reg it will be the weaker two pin diff.
Andy
Post #338917 18th Jun 2014 7:27am
Marky Boy
Hi all,
Can you advise if the diff etc. from a MY04 TD5 is the same as I have the same symptoms as David. Its got 53K on the clock and fine when cold but as soon as its up to temperature exhibits a real clunk when taking up drive etc.
With the wheels on the ground I am able to turn the front prop just like the one shown in the video while the rear has vitrually no movement to speak of.
Post #338958 18th Jun 2014 12:23pm
Make sure the hand brake is off before checking the rear..
But don't get under it unless fully secured first.
Post #338960 18th Jun 2014 12:43pm
Marky Boy
Ah ! Hadnt thought of that, will give it a go later, thank you.
Post #338962 18th Jun 2014 12:45pm
Cheshire110
Yep, diff it appears to be Big Cry
Spoke to a Land Rover mechanic 'off the record' and he says the same - fit a HD one. Will speak to ashcrofts and see what their advice is too.
Is it a DIYable job? Doesn't seem to complicated to remove half shafts, props and the open up the pinion casing?
Also it seems to be affecting steering a little now, that would all agree with diff right? Feels as if it's torque steering the wrong way around corners a little. Will take it slow! Cheers, David
Post #338965 18th Jun 2014 1:17pm
Cheshire110
Marky Boy wrote:
Hi all,
Obviously undo handbrake but secure the car somehow, my front prop turns as shown in video but the rear is fine (maybe 2/3 degrees of play but seems fine. Cheers, David
Post #338966 18th Jun 2014 1:18pm
Cheshire110
Andy
It's a 2010 ('10 plate)
Can you briefly explain the difference? How do I tell which I have? Cheers, David
Post #338968 18th Jun 2014 1:28pm
Weston18
England 1999 Defender 110 300 Tdi DCPU Tonga Green
Yes David it is very do-able for the home mechanic.
1. Prop off
2. Support vehicle with front wheels off the floor and remove them.
3. Remove rear steering drag bar.
4. Remove Filler bung, Drain oil.
5. I remove the swivel cups from the axle (easiest way) Pull them out so the shafts disengage from the diff.
6. Undo all the diff to axle casing nuts and remove. It is heavy so be careful.
Easily done within a day.
Goodluck
Post #338972 18th Jun 2014 2:28pm
Probably cost a fortune if done at a garage?
Post #338974 18th Jun 2014 2:43pm
keith
Same excessive movement and clunking on my 2012 110 . Dealer replaced the front diff last wk , No change , exactly the same never made a differance .
Back in this week for gearbox and clutch out .
Post #338975 18th Jun 2014 2:57pm
g-mack
dead easy if you buy the whole diff casing from them, more expensive obviously. im hoping to change mine someday for a complete front diff with ATB in it!!cost for unit is about £720 inc postage My 109 thread
my youtube channel
Post #338976 18th Jun 2014 2:58pm
ericvv
What can be considered as normal play of the front and the rear propshafts? I just checked mine, and both the front and the rear I can turn by hand just about 1 cm or 1/3 of an inch.... I presume that is entirely normal, yes?
Asking because I have had a a clunk when changing gears up too, which according to dealer was due to play in halfshafts which were subsequently replaced. When the truck is cold there is not the slightest clunk anymore now, but when it has warmed up, and when I change gears up with a bit of pressure on the accelerator, there still is a slight clunk. Nothing much, but just wondering if this is just due to that little play in the propshafts?
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #339638 21st Jun 2014 8:33am
Page 1 of 4 1234>
