Home > Puma (Tdci) > HELP PLEASE! Prop shaft, clunk, play
Page 2 of 4 <1234>
shaggydog
Defenders will always clunk it is inconvertible.
From the clutch you have:
Spline from engine to gearbox
Spline from gearbox to transfer box
Propshaft splines Front
Propshaft splines rear
Front prop input flange on Diff
Rear prop input flange on Diff
Front Diff left hand output flange
Front Diff right hand output flange
Rear Diff left hand output flange
Rear Diff right hand output flange
Front left wheel drive flange
Front right wheel drive flange
Rear left wheel drive flange
Rear right wheel drive flange.
If every one of those flanges has just 0.2mm of play, which they all will because they are a sliding fit by design, from the back of the engine they will have taken up 2.8mm of slack and that will cause a "clack" noise.
Obviously the more warn your flanges, the more slack you will have.
David, I'm afraid your Front Diff looks toast. I would look at getting an earlier HD version.
If you don't need a Limited slip or Locker diff I wouldn't bother fitting one as without use they will deteriorate and then not work when you need it.
Be weary though as the Spline numbers do jump around a bit between models so Ashcrofts will be able to help.
Post #339656 21st Jun 2014 11:21am
Cheshire110
Yeah mines currently in the indie, being taken apart monday and he will get back with some options then (HD/genuine/ashcrofts etc etc)
Also going to check the half shafts etc while they're out incase there's too much play there which seems a common issue, but normally age/mileage related not just failure. Cheers, David
Post #339660 21st Jun 2014 11:45am
Cheshire110
so cars back and running miles better now, no clunks and no slack Thumbs Up
this was what the old diff looked like!! Shocked
suspect it has been getting worse and worse for a while and one day just went and i should've realised its too clunky, but i guess its like the frogs in cold water being brought up to the boil - you don't notice gradual changes!! Cheers, David
Post #341501 28th Jun 2014 9:59pm
LR90XS2011
David
I would say you were lucky to get that just in time, another few miles and that could have caused a serious catastrophic failure. Thumbs Up DEFENDER 90 TDCI XS,
Post #341510 28th Jun 2014 10:40pm
jimbob7
driver abuse Whistle Pov.spec,ftw. 2006, 110,TD5.
Post #341514 28th Jun 2014 10:57pm
Similar thing happened to my front diff. There are pictures in a thread somewhere on here.
I have (at last) finally got my driveline clunk free, and at the moment it is a delight to drive (there, I've jinxed it now)! All it took was a new clutch, lubricating all moving parts of the gear levers, a new transfer box, Ashcroft ATBs in both axles, and Ashcroft HD halfshafts front and rear, Ashcroft HD CV joints, and Ashcroft HD drive flanges all round. It now drives like it should!
Post #341701 29th Jun 2014 11:02pm
g-mack
^^ so a quick easy fix then BW!! Shocked Very Happy My 109 thread
my youtube channel
Post #341704 29th Jun 2014 11:19pm
Four years and more cash than I'll admit to with SWMBO in earshot, but worth it! I'll enjoy it till the next bit breaks!
Post #341709 29th Jun 2014 11:46pm
GUM97
Ouch Shocked What did he do? Just put a new diff in? An engine to TDi for!
Post #341933 30th Jun 2014 9:48pm
Roy5695
United Kingdom 2011 Defender 110 Puma 2.2 XS DCPU Indus Silver
My early 2012 def90 is going back under warranty due to the same problem, I'll let you know the outcome.
Post #341979 30th Jun 2014 11:49pm
charlesteton
2011, 110 2.4, had clunk on gear change. Had rear diff seals redone and replaced drivers side half shaft under extended warranty, now very tight and no clunk.
Post #388942 16th Jan 2015 9:49am
martinfiattech
Can you tell by looking at the diff (without removing it) if it`s a two or four pin type. Or is it a chassis break point type thing.
I`ve got a 2011 my 90 so I assume it`s a four pin type. Excuse the spelling I`am better with spanners and wires.
Post #389160 16th Jan 2015 8:28pm
landy andy
Yours will be a 2 pin as it's a 90. You can tell via the diff fill hole.
Andy
Post #389238 16th Jan 2015 10:18pm
martinfiattech
Censored ! another thing to go wrong.
Thanks Thumbs Up Excuse the spelling I`am better with spanners and wires.
Post #389347 17th Jan 2015 12:41pm
Caterham
Couple of easy questions please;
Are front and rear diffs the same?
And should there be the same amount of rotational slack in the front and rear props (assuming hand brake is off) ?
Thanks
Post #402838 27th Feb 2015 7:41pm
Page 2 of 4 <1234>
