Home > Technical > Tdci 2.2 gearbox issues
Page 2 of 3 <123>
I wonder also if the problem is compounded by manufacturing tolerances in the gearbox extension and transfer box, and any play or backlash in the transfer box input gear bearings. anything which causes the extension shaft to oscillate will fret the splines.
In all seriousness the problem is not the basic design, it is the the lack of adequate initial lubrication. Even if you choose to drop the transfer box every 50k miles to lubricate the splines it really isn't a big burden, it doesn't take long to do.
Post #332005 19th May 2014 11:44am
natyeo
United Kingdom 2014 Defender 90 Puma 2.2 HT Santorini Black
No worries , is it easy to get at as I will grease it myself every 6 months or so? 2014 2.2 90 hard top , Warm M8000 , Scorpain winch bumper, Ashcroft rear atb
2012 2.2 tdci 110 Utility
1993 110 CSW Warn M8000 , Scorpain winch bumper , 2" lift , Roamerdive overdrive, on going
1971 Hybird 200tdi, 2 x truetracs,Extrem winch bumper, M8000, GKN overdrive & Coils 2" lift, Glynn Lewis cranked rear trail arms
1971 Series 3 88, Perkins 4203,M8000,SATs,O/D,
Post #332020 19th May 2014 12:46pm
munch90
no not easy, transfer box out to get at it
Post #332024 19th May 2014 1:08pm
blackwolf wrote:
.... Even if you choose to drop the transfer box every 50k miles to lubricate the splines it really isn't a big burden, it doesn't take long to do.
It does require you to remove the transfer box, so although not difficult it isn't exactly trivial. I certainly wouldn't do it every 6 months.
I suggested 50k miles (which is about every 2 years in my case Shocked ).
With some practice you can do it in a couple of hours including putting the tools away afterwards.
If the splines are worn, the parts cost about £100 to replace.
Post #332042 19th May 2014 2:05pm
Cuthbert
Is this problem on the 2.2 models related to the English or Scottish manufactured gearboxes?
Post #333125 23rd May 2014 10:48pm
Er, no Question
It is also not a "2.2 problem" but rather a Tdci problem since it is common on all Ford-engined Defenders.
Post #333140 23rd May 2014 11:28pm
Cuthbert
You might like to consider that the current 'Scottish' transmissions for Defenders are being manufactured and assembled by workers who are very keen to maintain their employment - quality and tolerances are to the fore.
Post #333511 25th May 2014 6:02pm
jomara
Scotland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
Hi Cuthbert is it Albion who are assembling the Defender transmissions?? I seem to have missed a thread Confused 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto
2022 110 D250 XS Edition - Gone
2024 110 D250 X-Dynamic HSE
Post #333641 26th May 2014 2:10am
ashtrans
Site Sponsor
It is not a question of who is assembling them, if the design is flawed, the design is flawed (which it is)
The spline is dry, it frets and wears, just like the LT77 and the R380, they learnt from that mistake !!!
Dave Dave
Post #333837 26th May 2014 10:29pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
do getrag have factorys in both scotland and england then ?? 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #333850 26th May 2014 11:37pm
big steve
http://www.getrag.com/media/products/manua...0_MT82.pdf 2015 2.2 tdci hardtop xs
Post #333854 26th May 2014 11:48pm
natyeo
17,000 iah 1st , 2nbd time at 42,000 , the 2012 2.2 90 has done it yet again at 56,897 third gearbox to transfer box coupling at 2 and half years old , what does the long term future hold , not impressed! Sad 2014 2.2 90 hard top , Warm M8000 , Scorpain winch bumper, Ashcroft rear atb
Post #362052 3rd Oct 2014 11:57pm
Fifth Horseman
If the coupler is being lubricated correctly on assembly, that rate of failure may suggest a slight misalignment between the gear and transfer boxes causing accelerated wear. It would be difficult to check though.
A mis-machined adaptor case is possible or more likely, one or more of the locating dowels could be missing.
Post #362106 4th Oct 2014 9:41am
munch90
not really common nowdays to have a casing machined wrong as there are done by machine , I would say maybe dowl missing
Post #362110 4th Oct 2014 9:56am
natyeo
Its back today , seems alot better , but I need to speak to the service manager on monday to see what they have done 2014 2.2 90 hard top , Warm M8000 , Scorpain winch bumper, Ashcroft rear atb
Post #362239 4th Oct 2014 9:53pm
Page 2 of 3 <123>
