Home > Puma (Tdci) > Spot light mounting Dilemma
SkyFallSilver
Kuwait
Hello,
I have installed my nudge bar A bar Genuine and now facing a problem installing my Warn 7 " HID spot lights, the instructions come with the lights that I can only install them facing up right position. I have the nudge bar with the winch version, it has to holes up in the bar where I can fit the lights going down.
Where can I get custom mounts for these lights or a solution ? 2016 Defender 90 Adventure Edition
Post #331560 17th May 2014 1:38pm
K9F
Take a few measurements, sketch a diagram of exactly what it is you need. Find a fabricating engineer and tell him I need two of these made from 1.5mm stainless steel please. Pay him what is due and bolt them to the existing bracket mounting bolts on the upper underside surface of your a bar.
Thumbs Up
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #331580 17th May 2014 3:22pm
SkyFallSilver
Kuwait
do you have a close picture how they attach from above ? , my lights cannot be installed pendent. 2016 Defender 90 Adventure Edition
Post #331691 18th May 2014 5:32am
ericvv
If you want to keep it all clean and tidy, get rid of the Warns, and buy something that fits, the below for instance.
These new Hellas will attach to your A-bar without any tinkering, and are thin enough to not require any drilling in the grill either.
You may have seen that kitoper on here installed them on his Hunter, and I can assure you they are about the nicest high quality LED driving lights I have ever seen.
http://www.hella.com/MicroSite/offroad/UK/...LED_GB.pdf You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #331692 18th May 2014 5:44am
SkyFallSilver
Kuwait
Where can i order these , I can't find someone who retails them ?
Found on UK for around the $3,141 is that a correct price? 2016 Defender 90 Adventure Edition
Post #331693 18th May 2014 6:11am
ericvv
No, of course not a correct price at all. Why don't you send a PM to kitoper, he surely can inform you of where he was able to order them from?
Also if you do a search on here for "Defender Hunter Edition", you will get a good view of how they look installed on page 5 and 6 of that thread. Thumbs Up
Post #331695 18th May 2014 6:37am
SkyFallSilver
Kuwait
Sent him a PM he showed me picture but didn't tell me where he got them from 2016 Defender 90 Adventure Edition
Post #331696 18th May 2014 6:38am
110 John
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Orkney Grey
I just used Wipac 6 3/4 inch driving lamps 55w have a total of 6 fitted, slim plastic shell nothing to rust and they do the job well for under �30 a pair posted ebay
URL=]
Post #331697 18th May 2014 6:59am
K9F
Keep it simple, take your vehicle AND lights to a fabricator, tell him exactly where you want the lights to be fitted and let him figure out and manufacture the bracket arrangement you will need.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #331705 18th May 2014 8:09am
SkyFallSilver
Kuwait
Just spoke to a german dealer, found 2 Hella LED LUMINATOR Compact. HE will provide me a quotation tomorrow (90% done). Going to sell Warn to a friend of mine. I found fabricators here but the quality of the work is bad. 2016 Defender 90 Adventure Edition
Post #331707 18th May 2014 8:28am
SkyFallSilver
Kuwait
Eric
Just got the lights shipped for 1,121.50 euro shipped. 2016 Defender 90 Adventure Edition
Post #332040 19th May 2014 2:03pm
