Home > Td5 > Handbrake light intermittently coming on when driving |
110MGD Member Since: 17 Oct 2013 Location: Wear Valley Posts: 153 |
Sometimes when driving along the light goes on and off intermittently. And flickers now and again even when fully released? Any ideas? Anyone had this before? 2001 Td5 CSW (weekend and snow mobile) Plenty of lights, M/T tyres EGR delete, roofrack, swing away wheel carrier, snorkel.
2016 E220 CDI Night Edition Estate 2014 VW UP! 2x D3 and 1x D4 GONE |
11th May 2014 9:11pm |
Check the brake fluid level in the reservoir, the warning light is also a low fluid warning light.
11th May 2014 9:18pm |
are sure it's to do with handbrake and not brake fluid level , worth checking that first
Thanks guys! It had a big brake overhaul discs pads calipers etc just over a week ago so hope there's plenty of fluid in I'll check tomorrow too dark now! 2001 Td5 CSW (weekend and snow mobile) Plenty of lights, M/T tyres EGR delete, roofrack, swing away wheel carrier, snorkel.
11th May 2014 9:20pm |
Sorry for my ignorance but will by CSW 2001 Td5 even have ABS?? 2001 Td5 CSW (weekend and snow mobile) Plenty of lights, M/T tyres EGR delete, roofrack, swing away wheel carrier, snorkel.
11th May 2014 10:53pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5873 |
I have the same on my TD5. If I push the handbrake lever down the light goes off.
My guess is, Its either a badly aligned switch or I need a spring to pull the lever down. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
12th May 2014 12:16pm |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1826 |
My 2001 TD5 Hard Top has ABS/TC...it was an option. Re: the light coming on, I'd check the switch on the handbrake as a prime contender. cheers simon |
12th May 2014 12:36pm |
ozzy57 Member Since: 14 Feb 2014 Location: Farnborough Posts: 221 |
Turn your ignition to position II, the ABS warning light will come on if you have it. It wasn't me! |
12th May 2014 6:06pm |
Click image to enlarge Voila. etc. It wasn't me! |
12th May 2014 6:08pm |
Maxxed_Ross Member Since: 06 Jun 2012 Location: Bathgate / North Sea Posts: 340 |
yup mine does the same thing if you don't push the lever all the way down |
12th May 2014 6:25pm |
I seem to have more lights than you Ozzy!
Click image to enlarge |
12th May 2014 6:32pm |
take it you have checked the brake fluid level
if the level is ok . check that the float in the brake is floating and not sinking , not uncommon for the float to get fluid inside it stopping it from floating completely and putting the light sometimes take float out and have a look at it you can normally just see if there is fluid in it |
12th May 2014 6:59pm |
seems you have traction control and a diesel filter water sensor too
mine has a water sensor but it's not plugged into anything |
13th May 2014 7:08am |
Yes, that's my 2002 reg 110. The build date on mine was January 2002 and first registered on May 1st the same year. Although it hasn't got electric windows and trimmed out in farmer trim it had ABS/TC fitted from the factory.
13th May 2014 7:48am |
