Home > Td5 > Handbrake light intermittently coming on when driving
110MGD
2001 Defender 90 Td5 CSW Epsom Green
Sometimes when driving along the light goes on and off intermittently. And flickers now and again even when fully released? Any ideas? Anyone had this before? 2001 Td5 CSW (weekend and snow mobile) Plenty of lights, M/T tyres EGR delete, roofrack, swing away wheel carrier, snorkel.
2016 E220 CDI Night Edition Estate
2014 VW UP!
2x D3 and 1x D4 GONE
Post #330409 11th May 2014 10:11pm
JWL
Check the brake fluid level in the reservoir, the warning light is also a low fluid warning light.
Post #330412 11th May 2014 10:18pm
munch90
are sure it's to do with handbrake and not brake fluid level , worth checking that first
Post #330414 11th May 2014 10:18pm
110MGD
Thanks guys! It had a big brake overhaul discs pads calipers etc just over a week ago so hope there's plenty of fluid in Thumbs Up I'll check tomorrow too dark now! 2001 Td5 CSW (weekend and snow mobile) Plenty of lights, M/T tyres EGR delete, roofrack, swing away wheel carrier, snorkel.
2014 VW UP!
Post #330416 11th May 2014 10:20pm
bear100
Had the same, loose connection on the ABS module
Thumbs Up 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #330419 11th May 2014 10:26pm
110MGD
Sorry for my ignorance but will by CSW 2001 Td5 even have ABS?? 2001 Td5 CSW (weekend and snow mobile) Plenty of lights, M/T tyres EGR delete, roofrack, swing away wheel carrier, snorkel.
2014 VW UP!
Post #330431 11th May 2014 11:53pm
excossack
I have the same on my TD5. If I push the handbrake lever down the light goes off.
My guess is, Its either a badly aligned switch or I need a spring to pull the lever down. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #330518 12th May 2014 1:16pm
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
My 2001 TD5 Hard Top has ABS/TC...it was an option.
Re: the light coming on, I'd check the switch on the handbrake as a prime contender.
cheers
simon
Post #330520 12th May 2014 1:36pm
ozzy57
2002 Defender 110 Td5 CSW Alveston Red
Turn your ignition to position II, the ABS warning light will come on if you have it. It wasn't me!
Post #330589 12th May 2014 7:06pm
ozzy57
Voila. etc. It wasn't me!
Post #330590 12th May 2014 7:08pm
Maxxed_Ross
Scotland 2001 Defender 90 Td5 CSW Cobar Blue
yup mine does the same thing if you don't push the lever all the way down
Post #330597 12th May 2014 7:25pm
JWL
I seem to have more lights than you Ozzy!
Post #330601 12th May 2014 7:32pm
munch90
take it you have checked the brake fluid level
if the level is ok . check that the float in the brake is floating and not sinking , not uncommon for the float to get fluid inside it stopping it from floating completely and putting the light sometimes
take float out and have a look at it you can normally just see if there is fluid in it
Post #330618 12th May 2014 7:59pm
Maxxed_Ross
seems you have traction control and a diesel filter water sensor too
mine has a water sensor but it's not plugged into anything Sad
Post #330703 13th May 2014 8:08am
JWL
Yes, that's my 2002 reg 110. The build date on mine was January 2002 and first registered on May 1st the same year. Although it hasn't got electric windows and trimmed out in farmer trim it had ABS/TC fitted from the factory.
Post #330710 13th May 2014 8:48am
