Home > Td5 > Handbrake light intermittently coming on when driving
Page 2 of 2 <12
johnszs
United Kingdom 2004 Defender 90 Td5 XS CSW Alveston Red
John what is the box under the dash for?
And the lower light, i havent noticed that on mine 2004 TD5 Defender 90 xs station wagon
Post #330815 13th May 2014 7:35pm
ozzy57
2002 Defender 110 Td5 CSW Alveston Red
Box is for aftermarket strobes and the light is the water trap(?) warning light. It wasn't me!
Post #330841 13th May 2014 8:57pm
johnszs
Ahh i see, that would figure. I will check mine tomorrow and see what else i miss when it starts 2004 TD5 Defender 90 xs station wagon
Post #330857 13th May 2014 9:16pm
albuquerque
JWL wrote:
I seem to have more lights than you Ozzy!
You TC light shouldn't be off ? Mine goes off after 2 or 3 seconds after switching on.
Post #331010 14th May 2014 6:00pm
dnorrishill
England 2014 Defender 90 Puma 2.2 XS CSW Aintree Green
My handbrake light was coming on while driving. It also stayed on sometimes when you put the handbrake lever down.
The solution was to spray a little WD40 down the cable (inside the outer casing as it were). I think there was crud in there and the WD40 sorted it out.
Post #331025 14th May 2014 6:47pm
MaxRPM
I get this problem in the winter. It's because the rubber gaiter is stiffer in cold weather and the handbrake lever is lifted slightly by the harder rubber.
Post #332713 22nd May 2014 8:59am
JWL
@albuquerque, I was a bit quick with the camera so as to get all the lights. They do their self test bit then all you get left with when the engine is running is the abs light until you move off and maybe the brake warning light if your handbrake is on.
Post #332737 22nd May 2014 10:12am
Blott
England 2002 Defender 90 Td5 HT Baltic Blue
My hand brake light was staying on. I could solve by pushing the handbrake lever right down but it felt springy. However, the source of the problem was with the cable in the drum. Over time the plastic sheathing on the cable rucks up and gets caught on the spring in the drum preventing it from returning to the completely "off "location hence why the lever would not drop right down. It also meant that at times the transmission brake was dragging just slightly. I fitted a new cable, adjusted and all is good both in the cab and no dragging. Blott
Post #357675 13th Sep 2014 9:23pm
Buddy2shoes
United Kingdom 2002 Defender 90 Td5 CSW Aintree Green
What handbrake light??????
Post #360610 27th Sep 2014 9:21pm
Buddy2shoes
Post #360612 27th Sep 2014 9:21pm
Orangeboy
Not just you
I've got no handbrake light or a switch / plunger I can see for it
2000 td5 ht
Post #362243 4th Oct 2014 10:19pm
Page 2 of 2 <12
