Home > Wheels & Tyres > 285 |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
Do you adjust your speedo for the extra radius? One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
18th May 2010 9:41am |
CFB Member Since: 13 Sep 2007 Location: Bradford, West Yorkshire Posts: 803 |
No, the original is way out anyway so it almost compensates Andy |
18th May 2010 11:08am |
AJS4X4 Member Since: 28 May 2008 Location: Surrey Posts: 793 |
285/75x16 on a 7J wheel, your choice boys, should be fitted on an 8J.
You all follow like Andy |
18th May 2010 5:06pm |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 |
Not me Andy, I'm a Wolf in sheep's clothing NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
18th May 2010 5:24pm |
Me neither.... 7J's, 8J's are bicycle wheels aren't they?..... If it's width you want the shoe's a size 10 If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
18th May 2010 6:24pm |
Well said k9 10j or nothing NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
18th May 2010 6:27pm |
Hello Karlos. Knew you'd be along... I won't be rushing out to buy anything for 'Justin' though..... Justin case I get a pull. Just 'Googled' 7J and 8J under images..look what came up! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
18th May 2010 6:31pm |
LOL K9, I think i just had a blond moment that day naiver will i me old matey getting remap tomoz NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
18th May 2010 6:35pm |
K9 That says it all Get your tyres from Mr whippy NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
18th May 2010 6:42pm |
In mitigation I did manage to find a similar vehicle with some 10Js.....
18th May 2010 6:56pm |
VXR MR Whippy with 10j OMG NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
18th May 2010 6:59pm |
LR09WA Member Since: 30 Apr 2009 Location: Perth Posts: 88 |
Sorry to bring this 285/75/16 debate up again.... but I found this on the http://www.procomp.com.au/ site claiming a 7inch rim is the minimum required rim size for there 285/75/16 all terrain...... so does any other tyre manufactures claim this as a minimum....
PART SIZES LOAD LOAD MAX. OVERALL DIAMETER OVERALL WIDTH TREAD WIDTH TREAD DEPTH RIM WEIGHT NUMBER (Inches) (Metric) RANGE SPEED LOAD Kg. (In.) (Metric) (In.) (Metric) (In.) (Metric) (32nds) (Metric) RANGE (In.) Kg. 160265 32X10.5R16 265/75R16 E 123Q 1550 31.7 805 10.5 267 8 203 16.4 13 7-8.5 22 160235 32X9.5R16 235/85R16 E 120Q 1400 31.8 807 9.4 238 6.9 175 16.4 13 6-7 19 16285 33X11.5R16 285/75R16 D 122N 1550 33 838 11.3 287 8.9 226 16.4 13 7-9 24 16305 33X12.5R16 305/70R16 D 118Q 1320 32.6 828 12 305 10 254 17.6 14 8-9.5 26 16315 35X12.5R16 315/75R16 D 121Q 1450 34.7 881 12.8 325 10.1 257 16.4 13 8-10 28 170265 32X10.5R17 265/70R17 E 121Q 1450 31.6 803 10.5 267 8 203 16.4 13 7-8 23 17285 33X11.5R17 285/70R17 D 121R 1450 32.8 833 11.5 292 9.2 234 16.4 13 7-8.5 23 1828560 31X11.5R18 285/60R18 B 116T 1250 31.3 795 11.7 297 9.7 246 12.6 10 8-10 20 1865275 32X11R18 275/65R18 E 123R 1550 32.2 818 11 279 8.8 224 17.6 14 7.5-9.5 23 Regards LR09WA |
26th May 2010 7:38am |
The Boy Member Since: 28 Aug 2008 Location: East Northants Posts: 1459 |
Don't know about that but I have always believed that for 285's it is a minimum of 8". But as others have said they run them on narrower wheels without any problem. Me I use 8.5". I personally would not want to go any wider because of the potential for wheel bearing wear.
Boy |
26th May 2010 3:59pm |
discocuzzy Member Since: 16 Jul 2008 Location: surrey Posts: 1200 |
305s on 8" for me You cannot teach stupid people to do clever things
26th May 2010 5:41pm |
