Home > Wheels & Tyres > 285 |
LR09WA Member Since: 30 Apr 2009 Location: Perth Posts: 88 |
So if I fit 285/75/16 on the boost rims with spacers, what are the down falls..... I want to set the car up to do a lot of boat towing on sand so I am keen to increase my tyre foot print, without effecting roadability to much....
27th May 2010 8:18am |
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 |
I ran 285 BFG MT`s on Boosts with spacers for over 2 years and no problems
27th May 2010 8:31am |
Thanks Mate... what spacers did you fit... |
27th May 2010 8:35am |
Sonic did you find much change in the roadability of the car, heavy steering, bump steer, vague steering or anything of the like...
27th May 2010 8:38am |
I had 40mm spacers from Rakeway Engineering The steering was a little heavier but not bad and no bump steer.
27th May 2010 9:09am |
Thanks
27th May 2010 9:23am |
PDH Member Since: 03 Dec 2009 Location: Shropshire Posts: 179 |
Im running 285's on boosts with 30mm spacers and no issues at all 20000 miles done so far and not an issue other than dirtier than normal car lol Puma 2.2 90 Stationwagon
27th May 2010 12:07pm |
Cibit Member Since: 26 Oct 2009 Location: Northumberland Posts: 424 |
Don't decrease your tyre pressures with 285's on 7" rims or the bead may pop 59 2.4 110 XS Utility 55 TD5 110 CSW Special Vehicle |
27th May 2010 12:44pm |
Be intersted to know what you're basing your opinion on as my Coopers due to their profile on-road (and wear pattern) appear to have less road-contact than the standard grabbers had??? If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
27th May 2010 1:52pm |
CFB Member Since: 13 Sep 2007 Location: Bradford, West Yorkshire Posts: 803 |
It's to do with the wheel off-set, the further out from normal, the higher the strain on wheel bearings etc. Andy
27th May 2010 3:50pm |
So it's offset which is more significant than width which affects bearing wear then? At between a paltry £14:99 to £20:50 for a bearing kit dependant where you buy I don't think I'll be rushing out to rip my 10Js off my vehicle and refit the ice-cream van ones? I think I'll take my chance on having to change them sometime, the bearings that is!
27th May 2010 5:20pm |
The Boy Member Since: 28 Aug 2008 Location: East Northants Posts: 1459 |
Correct There are other wear issues. I based my remarks on a life time of owning, driving and working with lr's. I once had a wheelbearing go and it oscillated on the stub axle and locked the front left wheel at about 35 mph. Still gave me the shock of my life though. But as K9 said it doesn't really matter if you have 10" it is just personal choice and that was all i was saying "It was my choise". Boy |
27th May 2010 7:32pm |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 |
Bearings at a tenner a go who gives a if they go every 12 months....not me NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
27th May 2010 8:03pm |
Very true! I wont say a word more on the subject |
27th May 2010 8:14pm |
