Painted the badly stained/faded grill,I used Halfords plastic trim spray,after I wet flatted it first with 1500 grit,quite pleased with the finish,not got the standard textured finish but a smooth satin black finish,I like it.
From this; ![]() Click image to enlarge[/img] To this; ![]() Click image to enlarge[/img] Gonna get a qoute for powder coating the bumper as it looks (naturally ![]() |
timbar Member Since: 30 Jul 2013 Location: Milton Keynes Posts: 245 ![]() ![]() ![]() |
Just went out to adjust my steering lock stops. Found someone seems to have already done it. 2009 110 XS Station Wagon
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 ![]() ![]() ![]() |
Adjusted my dipstick as it had become loose.
![]() Click image to enlarge Can never have enough extension bars ![]() Also changed the water pump and went for a quick run. Another problem (hopefully) solved |
Nobby Member Since: 09 Aug 2012 Location: Wiltshire Posts: 444 ![]() ![]() ![]() |
Fitted some parts and took it for a drive just to make sure. _______________________________
Puma Defender 90 |
ngarigo Member Since: 25 Nov 2011 Location: Alice Springs N.T. Posts: 81 ![]() ![]() ![]() |
followed my nose....
![]() Click image to enlarge image by Defender 90, on Flickr ![]() Click image to enlarge image by Defender 90, on Flickr Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming... 'Wow...! What a ride! MY11 90 |
Cakey Member Since: 19 Feb 2013 Location: Cheshire Posts: 468 ![]() ![]() ![]() |
Fantastic pictures ngarigo
![]() Hope you don't mind your my new screen save |
not at all
![]() 'Wow...! What a ride! MY11 90 |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 ![]() ![]() |
Are these HDRs and then fettled in PS?
mostly all shot on an iPhone 4, then worked up in snapseed.... Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming...
[quote="jimbob7"]
![]() Click image to enlarge That does look good ![]() Rather than powder coating have you considered doing it yourself with some POR15 and a chassis black paint? |
Cheers fella,DIY is "plan B", (still got some Rustoleum left from when I did mi chassis),depending how much the powder coater wants.Would also get a better finish with powder coat,providing they do a better job than the "factory",lol. Pov.spec,ftw. 2006, 110,TD5.
ClaireWright Member Since: 12 Oct 2012 Location: Warwickshire Posts: 609 ![]() ![]() ![]() |
New tax disc on and drove him for the first time since October !!! Love it
Vizsla Member Since: 18 Nov 2012 Location: Berkshire Posts: 96 ![]() ![]() |
Adjusted the steering stop locks. Probably the biggest single ( and cheapest) transformation ever made that alters the usability of the truck. Also Adjusted the tyre pressures down to 29psi at the front and 33psi rear (running 235 Contis on Boosts) as we mostly run unladen- except for the dogs.
Ride is much improved and we can now manouvre in tight spaces with relative ease. Considering spacers to improve turning and stance even further as I don't want to replace the Boosts yet ( recently refurbished under warrenty) for a bigger offset wheel and have lots of tyre tread remaining (so will wait before going to 265s) |
LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11240 ![]() ![]() ![]() |
Sold it
![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
