Home > Maintenance & Modifications > what oil ? |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2436 |
Once I uesed synth 5w40 Motul 8100 for the summer but my MPG dropped drastically. Back to the ford spec. Puma 110" SW
12th May 2010 1:12pm |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4722 |
On the receipt for my second service last week the oil used was listed as Castrol 0W/30. 1982 88" 2.25 diesel
12th May 2010 3:35pm |
Mobil1 ESP 5-W30 ACEA A5/B5 (superseded A1/B1) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License |
12th May 2010 7:53pm |
A1 Fuel economy petrol
A2 Standard performance level (now obsolete) A3 High performance and/or extended drain A4 Reserved for future use in certain direct injection engines A5 Combines A1 fuel economy with A3 performance B1 Fuel economy diesel B2 Standard performance level (now obsolete) B3 High performance and/or extended drain B4 For direct injection car diesel engines B5 Combines B1 fuel economy with B3/B4 performance Puma 110" SW ............................................................. Earth first. Other planets later |
12th May 2010 8:23pm |
this pics are better than 1000 words:
Click image to enlarge Click image to enlarge Nice to compare with lastest Ford WSS-M2C913-C Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
13th May 2010 8:06pm |
see HERE Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
13th May 2010 8:16pm |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2646 |
I'm also using Castrol Magnatec A1 5w30.
However, friend of mine is using Shell Helix HX7, and will switch to Shell Helix Diesel Ultra when it becomes available in South Africa in December. He supplies the oil to the stealer when it's due for a service, and they use it, but there is no agreement on what this means for the warranty. |
23rd Nov 2010 6:48am |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 |
Castrol Magnatec A1 5w30. NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
23rd Nov 2010 6:51am |
I have found another oil which conforms to the Ford specs: Fuchs TITAN XTR 5W-30 (http://www.opieoils.co.uk/p-991-fuchs-tita...e-oil.aspx) and another Fuchs one: Fuchs TITAN Supersyn F 5w-30 (http://www.opieoils.co.uk/p-68918-fuchs-ti...-a5b5.aspx)
The Opie oil website gives all the oils that conform to the Ford spec WSS-M2C 913-B: http://www.opieoils.co.uk/c-698-wss-m2c-913-b.aspx#Filter=[Sort=1*ava=0] And it looks like we should all be using WSS-M2C 913-C oils instead of the B spec, as per http://oilspecifications.org/ford.php:
23rd Nov 2010 9:35am |
BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253 |
Karl is that an "approved" oil, warranty wise? |
23rd Nov 2010 10:55am |
That is the oil that most LR stealers use, and according to the marketing blurb, was co-developed by Ford & Castrol for the Duratorque engines. |
23rd Nov 2010 11:02am |
DefenderOfTheEarth Member Since: 09 Nov 2010 Location: Cornwall, UK Posts: 1304 |
So will Castrol Edge 0W30 work okay?
That's what I use in the 335d so would be handy if the same oil works for both! Defender 110XS SW gone... now VW California 180 4 Motion. |
23rd Nov 2010 8:09pm |
Bergos Member Since: 08 Aug 2015 Location: Somewhere in Portugal Posts: 95 |
What exactly is "drastically"? My economy dropped from 10l/100km to 12.75l/100km (28mpg to 23mpg). Do you think that this could be caused by using 5W40 oil? Bergos LR Defender 110 HT 2007 (2.4 Puma) https://www.facebook.com/LR.Wanderlust/ |
2nd Sep 2018 9:25am |
for sure
also noted on my Defender Puma (5W50 vs 5W30 standard) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
2nd Sep 2018 10:45am |
