Home > Puma (Tdci) > off we go......no we don't
Page 2 of 4 <1234>
Caterham
? no idea but I'll have a look the weekend?
thank you.
Post #317815 21st Mar 2014 2:15pm
Caterham
I'll check it but presumably if there was a problem wouldn't there be a problem with the speedo?
Post #317866 21st Mar 2014 5:15pm
K9F
£5? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #317889 21st Mar 2014 5:53pm
Caterham
It's got to be double figures....
I've had no trouble with the valve caps or gear knob.
Post #317891 21st Mar 2014 6:10pm
K9F
^^^ Rolling with laughter Bow down
After due consideration I widthdraw my offer. You still have a sense of humour which is a good thing, brighten up my day and make me realise how lucky I am with my Defender!
Stick around..... Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #317892 21st Mar 2014 6:16pm
Caterham
Surely we've all got a sense of humour?
Very Happy
Have a great weekend Mal. Thumbs Up
Post #317894 21st Mar 2014 6:21pm
K9F
You too Caterham. May all your Defender worries be little ones. Thumbs Up Cool If you go through life with your head in the sand....all people will see is an ar5e!!
Post #317897 21st Mar 2014 6:32pm
K9F wrote:
At least we've moved on from the EGR blanking multiple threads. Whistle
What about Freedom of Speech. Whistle
Rolling with laughter â­ï¸â­ï¸God Bless the USA 🇬🇧🇺🇸 â­ï¸â­ï¸
Post #317899 21st Mar 2014 6:50pm
RustyM
England 2016 Defender 110 Puma 2.2 XS CSW Corris Grey
What about the fly by wire pedal? Do you have water leaking in and down to the pedal as moisture may be present until it is dispersed by using it a little? I only ask as this seems to be something you have not had issues with before Whistle 90 & Wolf
110 XS
Previously owned SI SII SIIa SIII & Light weight (air portable)
Post #317921 21st Mar 2014 7:36pm
Caterham
Pretty i'm safe on the water / pedal issue as I had the leaks sorted in the early days......
Either that or the pedal problem is being masked by other problems Laughing
Will have a look and give it a squirt of contact cleaner for good measure anyway.
Post #317932 21st Mar 2014 7:57pm
Happyoldgit
I thought you are going to have some experienced expert help with all these illusive issues Wayne, you are going to put yourself into an early grave worrying and eternally bouncing from one potential 'what if' issue or another. Steve.
http://forums.lr4x4.com
Post #317957 21st Mar 2014 9:07pm
Caterham
Someone has kindly offered to have a wee look in a few weeks....
Re the early grave as daft as it sounds I think you're right...... things like this really get to me (I know it's only a lump of metal at the end of the day but it's just the way I am) ...
Just drained the fuel filter again and I struggle to believe the amount of crud is acceptable.....i need to try and flush tank and replace fuel filter a few times and see if that helps.??
I've had the event blanked and I'm confident now that the egr wasn't a problem previously.
I have faith......the problem WILL get sorted......its just a matter of time Very Happy
Forgive my poor memory but I believe you were moving a little time back.... hopefully all went well? have a good weekend MOG. Thumbs Up
Post #317964 21st Mar 2014 9:25pm
What did the crud look like?
Post #317979 21st Mar 2014 10:21pm
Skeggy 90
England 2011 Defender 130 Puma 2.4 SW Bali Blue
Hi, I have had similar issues with a faulty clutch switch, It would be worth checking it. Check it is working with a multimeter.
Post #317989 21st Mar 2014 11:02pm
Caterham
Bw - will take photo of crud later (off on 8.5 mile run in minute)
Shaggy - I have suspected clutch switch before now and have disconnected it which made a big difference and as such made me think it was ok......that said and I know this sounds ridiculous..... lunch pedal squeaks but sometimes when it doesn't things seem to work well - I had put it down to nothing more than the placebo effect???
Will try and get someone to help me with the multi meter. Thanks.
Post #318018 22nd Mar 2014 6:17am
Page 2 of 4 <1234>
