![]() | Home > Puma (Tdci) > off we go......no we don't |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6300 ![]() ![]() ![]() |
guys.....not having any real experience with the def / tdci I'm wondering if the following is a 'normal' trait....
jump in car first thing in the morning, start up, pull off drive and then just before I'd go for second gear (so I'm guessing somewhere between 1500 - 1750 rpm) the engine dies......normally I'd just go for second however more recently I've deliverately left the 'go' pedal in the same position and hey presto the engine speed drops to tick over? any thoughts?......It only seems to do it when I first pull off from cold? I might have a few hours this weekend to do 'some digging' so to speak and any pointers would be much appreciate (and no I'm not going down the route of petol and matches.....at least not just yet ![]() One thing I want to look at is the ecu connections (is this as straight forward as you might expect...ie just pull the loom / plug out - good squirt of contact cleaner and replace). ? I'm looking t replace the fuel filter again but suspect I may have left this too late to order up for the w/e ? (I see a call to Steve at AF coming on). |
My guess is air in the fuel line.
Fuel slowly draining back while the engine's off leaving a 'bubble'. ![]() |
basically the engine revs drop back to tick over (c1000 rpm) without touching the clutch.
(normally when this happens I depress the clutch change to 2nd and away we go no probs) - clearly its not a problem as I change to 2nd and off I go........ the point I'm trying to get to is whether this is normal or not. if it isn't then clearly I like to understand whats causing it, try to resolve it and see if it has a positive effect on anything else. ![]() |
Norm4n Member Since: 31 Aug 2012 Location: Surrey Posts: 329 ![]() ![]() |
Not normal
oh.
part of me says likely because my other 'issues' seems like fuel starvation...... the other part of me says I aint got a clue.... if you're right....where would I start looking? I guess its no suprise that changing the fuel filter saw a short lived but obvious improvement based on the above? again when tank was replaced this had a great but short lived improvement? |
Norm4n......
![]() to you too ![]() |
in I know where I'm going to start looking......
I had some clowns replace my gearbox with a big hammer - might be worth having a look around there first ? anyone suggest 2nd best place to start looking? |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17443 ![]() ![]() ![]() |
A faulty VCV can cause similar symptoms.
please no......I've changed one......I can't bring myself to believe I need to replace it again
![]() also wouldn't this show up on diagnostics? |
If you've changed it then it's definately the prime suspect in my book. Sure you've not fitted it upside down, wrong orientation, in the right place, on the right vehicle.......
![]() FFS please sell it and move on! Group buy perhaps? We could have a ceremonial burning party! ![]() Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 21st Mar 2014 1:39pm. Edited 1 time in total |
who's gonna start the bidding
![]() fuel replaced right way up / round ect I did only replace the one to be fair - the one at the front nearest the dash board under the drivers seat. only joking. time to fit another filter to see if it improves things again.? |
Me I'll start. £4......
With 5843 members at £4 each I reckon we'd be in with a chance and we'd get some peace from the relentless 'Caterham's got yet another issue' scenario. At least we've moved on from the EGR blanking multiple threads. ![]() ![]() ![]() Treat every day as if it is your last....one day you will be right!! |
sorry about the multiple egr threads (it was an indicator of my frustration).
any how you should be feeling sorry for me.....my fingers are now only stubs which is making drivin a more difficult task.......a result of all this typing ![]() |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2420 ![]() ![]() ![]() |
Check the plug on the LT230. I think it is the speedo. Puma 110" SW
