Home > Puma (Tdci) > off we go......no we don't
Page 1 of 4 1234>
Caterham
guys.....not having any real experience with the def / tdci I'm wondering if the following is a 'normal' trait....
jump in car first thing in the morning, start up, pull off drive and then just before I'd go for second gear (so I'm guessing somewhere between 1500 - 1750 rpm) the engine dies......normally I'd just go for second however more recently I've deliverately left the 'go' pedal in the same position and hey presto the engine speed drops to tick over?
any thoughts?......It only seems to do it when I first pull off from cold?
I might have a few hours this weekend to do 'some digging' so to speak and any pointers would be much appreciate (and no I'm not going down the route of petol and matches.....at least not just yet Very Happy )
One thing I want to look at is the ecu connections (is this as straight forward as you might expect...ie just pull the loom / plug out - good squirt of contact cleaner and replace). ?
I'm looking t replace the fuel filter again but suspect I may have left this too late to order up for the w/e ? (I see a call to Steve at AF coming on).
Post #317785 21st Mar 2014 1:31pm
Swollock
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Bonatti Grey
When you say the engine dies, do you mean that it stops or the revs drop to tick over.
Mine can be a bit of a fiddle when cold from 1st to 2nd, but I have found it best to remove my foot full from the accelerator before even touching the clutch, the ECU then seems to do the rest in matching RPM etc for the gear change. 2008 Defender 110 XS CSW
Volvo S60 T8
Triumph 1200 Rally Explorer
G0UBX
Post #317786 21st Mar 2014 1:38pm
Laurie
My guess is air in the fuel line.
Fuel slowly draining back while the engine's off leaving a 'bubble'.
Post #317787 21st Mar 2014 1:48pm
Caterham
basically the engine revs drop back to tick over (c1000 rpm) without touching the clutch.
(normally when this happens I depress the clutch change to 2nd and away we go no probs) - clearly its not a problem as I change to 2nd and off I go........
the point I'm trying to get to is whether this is normal or not. if it isn't then clearly I like to understand whats causing it, try to resolve it and see if it has a positive effect on anything else.
Thumbs Up
Post #317788 21st Mar 2014 1:51pm
Norm4n
Not normal Laughing
Post #317792 21st Mar 2014 2:06pm
Caterham
oh.
part of me says likely because my other 'issues' seems like fuel starvation......
the other part of me says I aint got a clue....
if you're right....where would I start looking?
I guess its no suprise that changing the fuel filter saw a short lived but obvious improvement based on the above?
again when tank was replaced this had a great but short lived improvement?
Post #317797 21st Mar 2014 2:17pm
Caterham
Norm4n......
Laughing
to you too
Laughing
Post #317798 21st Mar 2014 2:20pm
Caterham
in I know where I'm going to start looking......
I had some clowns replace my gearbox with a big hammer - might be worth having a look around there first ?
anyone suggest 2nd best place to start looking?
Post #317800 21st Mar 2014 2:25pm
A faulty VCV can cause similar symptoms.
Post #317801 21st Mar 2014 2:26pm
Caterham
please no......I've changed one......I can't bring myself to believe I need to replace it again
Big Cry
also wouldn't this show up on diagnostics?
Post #317803 21st Mar 2014 2:29pm
K9F
If you've changed it then it's definately the prime suspect in my book. Sure you've not fitted it upside down, wrong orientation, in the right place, on the right vehicle.......
Whistle
FFS please sell it and move on! Group buy perhaps? We could have a ceremonial burning party! Cool If you go through life with your head in the sand....all people will see is an ar5e!!
Post #317804 21st Mar 2014 2:35pm
Caterham
who's gonna start the bidding Very Happy
fuel replaced right way up / round ect
I did only replace the one to be fair - the one at the front nearest the dash board under the drivers seat.
only joking.
time to fit another filter to see if it improves things again.?
Post #317805 21st Mar 2014 2:38pm
K9F
Me I'll start. £4......
With 5843 members at £4 each I reckon we'd be in with a chance and we'd get some peace from the relentless 'Caterham's got yet another issue' scenario.
At least we've moved on from the EGR blanking multiple threads. Whistle
Rolling with laughter Bow down If you go through life with your head in the sand....all people will see is an ar5e!!
Post #317806 21st Mar 2014 2:42pm
Caterham
sorry about the multiple egr threads (it was an indicator of my frustration).
any how you should be feeling sorry for me.....my fingers are now only stubs which is making drivin a more difficult task.......a result of all this typing Rolling with laughter
Post #317809 21st Mar 2014 2:46pm
MK
Check the plug on the LT230. I think it is the speedo. Puma 110" SW
Post #317814 21st Mar 2014 3:07pm
Page 1 of 4 1234>
