![]() | Home > Maintenance & Modifications > Air box mod and decat |
mark_d Member Since: 07 Sep 2013 Location: Northern Ireland Posts: 266 ![]() ![]() |
Hi Pete, Do you have a DXF file for the other piece of metal work in your post? It looks like the shape of the plastic OEM intake cover. Thanks, Mark http://defender90xs.blogspot.co.uk/ |
psimpson7 Member Since: 20 Nov 2013 Location: Gold Coast, Qld. Posts: 221 ![]() ![]() ![]() |
Hi Pete,
How are you getting on with the replacement pipe section to the airbox? Rgds Pete |
theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862 ![]() |
I have something similar in mind to mod the fitment I already have you should have enough room foe fit that elbow
Im using a flexy hose at the minute with a 4 inch diameter |
H4mmy90 Member Since: 21 Apr 2013 Location: Taunton Posts: 81 ![]() ![]() |
![]() Click image to enlarge There's mine out!! Noticed a difference in drivability in first and second doesn't cough and stutter like it did before, well worth the 30min to take out!! Looking at the pipe work there is defo massive restrictions still |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20706 ![]() ![]() |
Am I just dumb but why is it I can't work out how to remove the impeller thing? Do you have to cut it out of something? Or was it because I didn't take the whole air box out? I took the filter out from inside and couldn't see or feel any sign of it. WeWillWinπ¬π§πΊπΈ
β½οΈπ’οΈβοΈπ§°πͺ Last edited by custom90 on 8th Mar 2014 8:27pm. Edited 1 time in total |
Custom90steve
It's an easy job. I'm not saying how I did it is the rite way and I'm sure others will advise better. I just took the lid off the air box and removed filter not to forget unclipping wires from the lid Undid the jublie at each end of the pipe from air box to turbo to gain access to the dirty air feed pipe Remove the bolt that holds the dirty pipe to the inner wheel arch to give a bit of slack Then look into the air box and you will see where it lets the air in like a bit of tube patruding in, I then slid a 1/4 extension bar up inside the air box and on the top of the tube bit you can see like two plastic nipples which I pushed in with a flat head an then with the extension bar pushed the fan thing loose I then lifted the air box slightly and pushed down and wiggled the dirty air pipe and got the mrs to slide out the fan thing Then put it all back together |
Sorry for the crude description, would be easier to show than describe
Cheers, I'll have a look again soon. I must admit I only had a look really.
So the access is from underneath then? WeWillWinπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
For access I removed the blank on the wing top and managed to fit the pipe work. Although I attenoted to modify the abox without removing it and I damaged it. Being a brute
Well I did the air box mod today, a lot bigger job and more work than I thought but I got there in the end. Not only did I remove the water separator but modified the box too. I'll try and get some photos up later.
![]() β½οΈπ’οΈβοΈπ§°πͺ |
Okay here's the photos:
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge I haven't driven yet so I don't know what the difference will be, I've modified the box carefully being careful not to damage anything other than what I wanted to remove. I used a soldering iron to melt away what I wanted, time consuming and crude though and made sure I didn't breathe any fumes. In the last photo you can see what I finished it up as for now. Finished rough and I need to remove a little more of the lower collar area, but I'll tidy up the edges and make it look cleaner with a file etc when I get the chance. WeWillWinπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
Well I had a little test drive today and I agree with the previous comments about a bit more go in it in lower gears.
There generally seems to me to be a better throttle response especially if easing off and then you need to accelerate off again. Less lag there. ![]() Glad I did it now. WeWillWinπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
landybehr Member Since: 17 Apr 2013 Location: -D- Posts: 173 ![]() |
do your r/h Defenders also have the bloody thing of a air box/collector for the heating is in the way on the right inner wing too ?
If so - has anybody had a closer look at it and can assess whether it could be deformed (e.g. by means of a heat gun) to release some room between itself and the wing to let a bigger intake-air-pipe pass ? The idea came to be because I have a snow cover - don΄t know if my thought is valid - and this cover prevents ingress of much water also. So if there was a big air collector made to aid air/water seperation, this aspect could be abundant. |
at what revs does this mod have any effect on increasing the amount of air drawn in ?
