Home > Maintenance & Modifications > Puma Gearstick rattle / vibration cure guide (with photos)
Page 1 of 6 123456>
After reading the advice on here about how to cure the Gearstick rattle (in particular 5th. & 6th) I decided to make a little photo guide for others benefit from that have had the same issue.
I've had the Gearstick vibration noise for a long time and never got around to curing it until yesterday.
Thumbs Up
1) start removing the gaiter off of the stick by pushing it down:
2) And further until it's off of the stick, note the clips you can see each side that lock over the white part:
3) Gently pull these clips back each side both at the same time and the stick should pop out:
4) Lift Gearstick up and remove:
5) Now you can see the weights (metal) that rattle when in higher gears.
6) Now superglue the weights to the body of the stick like so:
7) Note you can see the glue along each edge of each weight, repeat this in all areas:
8 ) In my case I left the stick with the glue on for an hour as per its instructions to fully cure:
Once the hour had passed I refitted then left overnight but it would be cured anyway all the same.
Refitting of the stick is just the reverse of above but the gaiter is a bit tricky to get back on and over the stick but not too bad.
I did this mod yesterday and tested it today and rattle is gone in 5th and 6th. Mr. Green
The glue I used isn't specifically required for this job but if you don't already have any I used this:
http://www.ebay.co.uk/itm/SUPERGLUE-SUPER-...5645643c37
Cheap, but it's extremely strong. Shocked I've used it on other items like my EL wire with excellent results.
Apologies in advance for the photo quality, it was a full day and used phone.
Mr. Green
Steve TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #314310 7th Mar 2014 4:56pm
Cheshire110
perfect! cheers steve Cheers, David
Post #314312 7th Mar 2014 5:00pm
Thumbs Up Just thought as I was at it I may as well take some photos etc. TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #314321 7th Mar 2014 5:12pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
It would seem on your gear stick connection there was no grease. On mine it was covered in silicon grease, maybe the dealer as it was an ex-demo and I only got the buzz after a couple of hours continuous running, , so glue would not have worked. I used some small plastic cable ties to secure the weights. Same effect , gear stick buzz gone and it has been 3 years now. Whistle LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #314330 7th Mar 2014 5:47pm
There was some grease there, the photos just don't show it properly. TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #314331 7th Mar 2014 5:49pm
GUM97
Nice guide Steve, as usual! Thumbs Up An engine to TDi for!
Post #314343 7th Mar 2014 6:30pm
MartinK
Should be stickied Thumbs Up Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #314347 7th Mar 2014 7:03pm
Looks like Martin has done. Mr. Green TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #314355 7th Mar 2014 7:32pm
landys1
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Santorini Black
Nice one, that's exactly how I did it (but you explained it much better AND photos Bow down ). Amazing how such a simple fix improves the driving experience.... 1959 Series 2 Ragtop
1989 SWB Stationwagon
1998 300Tdi Hard Top and 2012 2.2 Puma Hardtop (at work)
2011 Puma 90 2.4 XS
Post #314361 7th Mar 2014 7:57pm
Indeed, it may have been you that mentioned how to do it and what to do. Have to give credit where credit is due to those who have mentioned it before.
I just locked the fact that it's a common issue and people myself included often wanted to know what to do. TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #314366 7th Mar 2014 8:07pm
landys1
Thumbs Up 1959 Series 2 Ragtop
2011 Puma 90 2.4 XS
Post #314442 8th Mar 2014 8:39am
carrotbay
United Kingdom 2008 Defender 110 BMW M57 3.0 Diesel XS CSW Auto Santorini Black
This is what I like about this forum .. Great advice .. 5 min job making a much nicer drive Thumbs Up 2008 Defender 110 XS SW - M57N2 / 6HP28X
Post #318814 24th Mar 2014 8:58pm
At least it means if you carry passengers they don't think your driving a bone shaker. Laughing TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #318838 24th Mar 2014 9:55pm
Nobby
England 2010 Defender 90 Puma 2.4 CSW Santorini Black
Well done and thank you Bow down added to my list to do. _______________________________
Puma Defender 90
Post #318845 24th Mar 2014 10:18pm
Thumbs Up Well worth it to do. TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #318853 24th Mar 2014 10:28pm
Page 1 of 6 123456>
