![]() | Home > Puma (Tdci) > Same panic moments but........... |
I want in & out Thermometer, bought with green illumination very nice........BUT
Panic!!!!!!!! I need to cut the facia........... ok, go on.......... this is the results............. ![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge I like the sunday hobby work....... please leave your feedback on my new little jobs..... Installed new Becker Cascade Pro Radio, Navi & Phone too...... ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() ![]() IID Pro MV License |
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 ![]() ![]() ![]() |
i would say it looks like a factory fit but it looks straight and secure and fully functioning so i won;t
![]() good job sir ![]() |
this is my goals on my Defender projects.... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
jlerra Member Since: 10 Jul 2009 Location: Gibraltar/London Posts: 149 ![]() ![]() ![]() |
Hi,
can I inquire as to the model of the radio you've fitted to your truck and the fitting - did you have to change the wiring of the vehicle at the back of the dash to fit the new radio? Does it sound good on the speakers or did you change the speakers aswell? Would be interested to know regards Joe 'El pepe flamenco' JLS 'El Pepe Flamenco' |
The radio is the Becker 7941 Cascade Pro, se here fore more details. for the installation you need ![]() 1. take the "speed" and "reverse" signals from the dashboard connector, not so difficult. 2. install the GPS and the GSM aerials 3. install the h/f microphone and 4. I have put the cd charger inside the cubby-box (job done with my previous Becker Radios) for the sound quality, the original mid and tweeter are good BUT I add an active subwoofer because the sound with the original speakers is absolutely without bass (one problem is the shape of the original installation where there isn't separation from the rear and the front of the loudspeakers) If you want I have an Becker Traffic pro 4723 (green illumination) for sale In this image is red (taken from becker site) but mine is green illuminated ![]() with the lastest 2009 CD MAP, PM me if interested. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
here or here: (copy and paste the address; it's too long for the ipertext forum engine) [url]http://cgi.ebay.it/CHECKTEMP-CHECK-TEMP-INNEN-AUsENTHERMOMETER-MIT-EXTRAS-/170418568064?cmd=ViewItem&pt=Autoteile_Zubeh�r&hash=item27adbcfb80#ht_1563wt_1167[/url] Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2669 ![]() ![]() ![]() |
I have the Madman EMS system, which monitors EGT, Transfer box oil temp, Coolant temp, Coolant level, oil pressure, and voltage.
Also involved cutting into the dash, but it looks very neat ![]() ![]() |
These posts are giving me ideas (dangerous I know
![]() How much room is behind these side panels? Just wondering if can fit a unit about 3" long, 1" high and about 2.5" deep. Would that fit in the side panel? Would be useful to know before I start dismantling things Brendan |
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 ![]() ![]() ![]() |
2.5" deep? Wouldn't that be called a glory hole? You should ashamed on a family forum like this
a lot of room, from 15 cm to 20 cm. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
LR09WA Member Since: 30 Apr 2009 Location: Perth Posts: 88 ![]() ![]() ![]() |
How do you find the becker set up, this is going to be my choice of stereos and not set on which to purchase yet... |
I don't understand your question...... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
is it good quality and works well 2.4 90 XS 1968 1/32 scale Britains 109 Pick up. |
For a good sound quality IT IS NECESSARY TO INSTALL AN ACTIVE SUBWOOFER (mine is Alpine). Becker radios have an outstanding sound quality inside, so it is easy to setup the radio for quality listening. By the way, you must know that my car have a lot of noise killing applications (from me) and the only noise that I'm not able to reduce is the windy turbolences noise (after 120km/h) ....... I love Becker radio, it is perfect machines, and you forget the tomtom, garmin and so on. The very added value is the goniometer, you can drive without GPS signal and the navi know exactly where you are.... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
