Home > Puma (Tdci) > Same panic moments but...........
dgardel
Italy
I want in & out Thermometer, bought with green illumination very nice........BUT
Panic!!!!!!!! I need to cut the facia...........
ok, go on..........
this is the results............. Bow down
I like the sunday hobby work.......
please leave your feedback on my new little jobs.....
Installed new Becker Cascade Pro Radio, Navi & Phone too......
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #31269 2nd May 2010 4:33pm
double cab happy
England 2007 Defender 110 Puma 2.4 DCPU Java Black
i would say it looks like a factory fit but it looks straight and secure and fully functioning so i won;t Laughing
good job sir Thumbs Up
Post #31272 2nd May 2010 5:13pm
dgardel
Italy
this is my goals on my Defender projects.... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #31273 2nd May 2010 5:20pm
jlerra
Gibraltar 2007 Defender 90 Puma 2.4 XS CSW Java Black
Becker radio fit
Hi,
can I inquire as to the model of the radio you've fitted to your truck and the fitting - did you have to change the wiring of the vehicle at the back of the dash to fit the new radio?
Does it sound good on the speakers or did you change the speakers aswell?
Would be interested to know
regards
Joe
'El pepe flamenco' JLS
'El Pepe Flamenco'
Post #31277 2nd May 2010 7:24pm
dgardel
Italy
Re: Becker radio fit
jlerra wrote:
Hi,
regards
Joe
'El pepe flamenco'
The radio is the Becker 7941 Cascade Pro, se here fore more details.
for the installation you need Whistle :
1. take the "speed" and "reverse" signals from the dashboard connector, not so difficult.
2. install the GPS and the GSM aerials
3. install the h/f microphone
and
4. I have put the cd charger inside the cubby-box (job done with my previous Becker Radios)
for the sound quality, the original mid and tweeter are good BUT I add an active subwoofer because the sound with the original speakers is absolutely without bass (one problem is the shape of the original installation where there isn't separation from the rear and the front of the loudspeakers)
If you want I have an Becker Traffic pro 4723 (green illumination) for sale
In this image is red (taken from becker site) but mine is green illuminated
with the lastest 2009 CD MAP, PM me if interested. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #31281 2nd May 2010 8:09pm
chris h
United Kingdom 2009 Defender 110 Puma 2.4 SVX Station Wagon Santorini Black
Where did you get the thermometer? It suits the landy very well. Only one I have seen in UK is silver and blue unit that won't look right.
Post #31287 2nd May 2010 9:03pm
dgardel
Italy
here
or here: (copy and paste the address; it's too long for the ipertext forum engine)
[url]http://cgi.ebay.it/CHECKTEMP-CHECK-TEMP-INNEN-AUsENTHERMOMETER-MIT-EXTRAS-/170418568064?cmd=ViewItem&pt=Autoteile_Zubehör&hash=item27adbcfb80#ht_1563wt_1167[/url] Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #31292 2nd May 2010 9:35pm
Naks
I have the Madman EMS system, which monitors EGT, Transfer box oil temp, Coolant temp, Coolant level, oil pressure, and voltage.
Also involved cutting into the dash, but it looks very neat Smile
Post #31314 3rd May 2010 6:59am
leeds
These posts are giving me ideas (dangerous I know Rolling with laughter )
How much room is behind these side panels?
Just wondering if can fit a unit about 3" long, 1" high and about 2.5" deep. Would that fit in the side panel?
Would be useful to know before I start dismantling things
Brendan
Post #31316 3rd May 2010 8:17am
110SEB
2.5" deep? Wouldn't that be called a glory hole? You should ashamed on a family forum like this Rolling with laughter Whistle
Post #31317 3rd May 2010 8:33am
dgardel
Italy
a lot of room, from 15 cm to 20 cm. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #31318 3rd May 2010 8:48am
LR09WA
Australia 2009 Defender 110 Puma 2.4 SW Stornoway Grey
dgardel wrote:
jlerra wrote:
Hi,
regards
Joe
'El pepe flamenco'
and
How do you find the becker set up, this is going to be my choice of stereos and not set on which to purchase yet...
Post #31319 3rd May 2010 8:57am
dgardel
Italy
I don't understand your question...... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #31332 3rd May 2010 11:39am
Grockle
is it good quality and works well 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #31333 3rd May 2010 12:09pm
dgardel
Italy
For a good sound quality IT IS NECESSARY TO INSTALL AN ACTIVE SUBWOOFER (mine is Alpine).
Becker radios have an outstanding sound quality inside, so it is easy to setup the radio for quality listening.
By the way, you must know that my car have a lot of noise killing applications (from me) and the only noise that I'm not able to reduce is the windy turbolences noise (after 120km/h) .......
I love Becker radio, it is perfect machines, and you forget the tomtom, garmin and so on.
The very added value is the goniometer, you can drive without GPS signal and the navi know exactly where you are.... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #31337 3rd May 2010 1:36pm
