![]() | Home > In Car Electronics > CB & aerial UPDATE now fitted :) |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2770 ![]() ![]() |
I'm a step ahead of you there
![]() Put some Velcro tape (the soft half) on the mount and some on the roof itself to protect ![]() Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1826 ![]() ![]() ![]() |
I did exactly the same, great solution... ![]() cheers simon |
party monkey Member Since: 31 Dec 2010 Location: Oxon. Posts: 1311 ![]() ![]() ![]() |
Just in case you haven't done it already David, tune the unit to the UK frequency band before you go on the forthcoming plains trip.
![]() I only say that as your piccy of 14th Dec suggests it's was defaulting to the EU band. Jon - 110 td5 [sold]. Currently Defenderless. |
Hmm ok is that easy?
Guess I'll find instructions in the booklet? Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
Typically (well on my COBRA and INTEK units), it's a hidden menu that you access by holding a menu/mode button down with the power off and then power up the unit.
I suspect it will be one of the first things in your user manual though. Jon - 110 td5 [sold]. Currently Defenderless. |
Will have a read of the instructions tomorrow morning
![]() Cheers for the heads up ![]() Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
SailingTom Member Since: 19 Nov 2013 Location: ESSEX Posts: 1725 ![]() ![]() |
Hi David
I know its getting fussy now, more of a question really. But was there a reason for mounting it on the left each time? Only reason I ask is I'd of thought you would get it knocked less on the right (away from hedges and overhanging tree's) Might be an obvious reason you cant, but just seems more protected like the car radio aerial. Cheers Tom Defender puma dormobile camper |
Absolutely no reason actually! Think it was just the side with the light when I was doing it maybe? Maybe just facing the house? Haha! Interesting how the human mind works
![]() Hadn't thought about that, think it should be well protected at the back though. Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
Haha nice honest answer!
![]() Yeah it should be fine, just thought it would protect it more as you do laning and was curious if there was a reason for the left. A friend of mine made a nice mounting off the top spare wheel nut so it cant scuff the paint at all although yours probably gets clearer reception. Looks a nice compact unit in yours though! Cheers Tom Defender puma dormobile camper |
Yeah it's a nice fitting, secured well into the gutter and aerial just screws in when I'm using it...
Really pleased You can probably see it better here: ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
