Home > Puma (Tdci) > trailer electrics for puma |
Landyman,
Can't really advise on availability of 'plug and play' trailer wiring. Answer probably lies in diagrams but don't have the time to look on your behalf at the moment, sorry! Nevertheless can assist with diagrams. PM sent. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
8th Feb 2010 1:23pm |
landyman1 Member Since: 11 Jul 2009 Location: Pembrokeshire,South Wales Posts: 57 |
p.m. received
No urgency, just grateful when time permits. Thanks again 1981 series 3 swb gone 1986 v8 110 station wagon current 2009 puma 110 xs utility station wagon latest addition |
9th Feb 2010 9:23am |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
Like this ? Clicky One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition |
10th Feb 2010 9:24pm |
cobs Member Since: 12 Jun 2008 Location: North Yorkshire Posts: 336 |
landyman1 - in LRO this month www.mailorder4x4.com have genuine Landrover S type kit for £44.96 - don't know if this is a good price or not but may be worth a look
11th Feb 2010 10:29pm |
Cobs,
Many thanks for info. Yes very good price but unfortunately offer is for TD5 kit which is different than puma. waiting to see what they come back with for puma. thanks again. 1981 series 3 swb gone 1986 v8 110 station wagon current 2009 puma 110 xs utility station wagon latest addition |
14th Feb 2010 11:02am |
niglyn Member Since: 12 Jun 2009 Location: Surrey Posts: 82 |
I fitted genuine LR 12N & 12S
The 12N just plugs into the connector under the wheelarch, you need to remove the plastic liner, just two screws. The 12N wiring also incorporates another connector which in turn plugs into the 12S loom this is for fog or reverse lights (i cant remember which). The 12S loom is adjustable for 90, 110 or 130 models. The loom is 'telescopic' you pull it out to the correct length for the vehicle. The short bit of the 12S loom runs under the wheelarch to connect to the connector on the 12N loom. The rest of the loom has to be run under the vehicle up into the battery box. This is where you fit the relay and connect to the battery. There is a grommet in the battery box, so no holes need to be drilled. From here a single wire comes from the battery box, under the dash board and up to a switch to the left of the radio. You need to remove the radio, pop the switch out to get to one of the wires (white/green) and scotch-lock on the single wire. This is for ignition sense. LR want you to drill a hole for this wire to exit the battery box, what I did was to run the wire out of a spare hole and extend the wire so it would reach. All make sense? The genuine LR kit does come with instructions. It is of the new type which only has one relay. This is fine for newer caravans, 96ish onwards I think. Older caravans required a 'split charge relay' to charge the battery and a second relay which would provide power for the fridge. With modern alternators, a split charge relay is not needed, so the relay fitted in the LRs battery box is actually for the fridge. The charging system for the caravan battery is incorporated in the caravan electrics. It takes its feed from the unswitched 12 supply from the LR, via a relay, which is controlled via the fridge feed. Blimey, I think I have finished. There is no great advantage buying a genuine LR 12S over an aftermarket one other than it is simpler to connect to the reverse light by simply plugging into the connector on the 12N loom. Just make sure the aftermarket loom is long enough for the LR. The genuine 12N is worth the money as it is so simple to fit, just plug it in. |
14th Feb 2010 8:13pm |
Well. Even I can manage that. great bit of information, thanks for the trouble. will get a 12s kit and start crawling about underneath. let you know when I,m done. If you don't hear back you 'll know I've crisped the wiring and too embarassed to admit it. 1981 series 3 swb gone 1986 v8 110 station wagon current 2009 puma 110 xs utility station wagon latest addition |
14th Feb 2010 11:14pm |
GREENPUMA Member Since: 12 Feb 2010 Location: devon Posts: 17 |
Some useful info there.
I'm just about to tackle this job. Do you have a part number for the correct 12S loom? I contacted LR and they gave me two numbers. STC8874 and LR005921, but they didn't know which was the correct one. Aparently there were less parts with the first number, so that would seem to fit with your comments re less relays etc. thanks, Pete |
6th Apr 2010 5:00pm |
I think LR005921 is the correct one.
The other one seems to be very similar but I wonder whether it was for an older variant (Tdi?) as it is often advertised as "Defender or Discovery 1" see ebay One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
6th Apr 2010 5:18pm |
willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789 |
Don't forget when you need parts contact TLO on the disco3 forum and you will get a big discount with prompt service from the most knowledgable land rover parts man in the UK Original Member Pie n Pea Club.
110 HCPU Tipper |
6th Apr 2010 6:31pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5038 |
Ive just had a look for him and cant find a TLO listed...is it me? Mike |
6th Apr 2010 10:14pm |
Try this
http://www.disco3.co.uk/forum/member2459.html Original Member Pie n Pea Club. 110 HCPU Tipper |
7th Apr 2010 5:46am |
Done Thanks Mike |
7th Apr 2010 8:37am |
Chunk Member Since: 19 Oct 2009 Location: County Durham Posts: 154 |
TLO sorted me out with a Cargo Barrier with discount thanks to Willy here.
Much obliged. |
7th Apr 2010 9:38am |
