Home > Puma (Tdci) > trailer electrics for puma
landyman1
United Kingdom 2009 Defender 110 Puma 2.4 USW Stornoway Grey
Hi folks.
I need to add a 12s socket to the rear of our puma 110. 12 n already fitted, but now need to charge a trailer battery etc..
Anyone know if wiring instructions come with it if I buy the kit from a dealer? Is it a plug in set up or will I need to add a relay and break into the loom? Am reasonably competent do it yourselfer but without access to wiring diagrams want to avoid creating disasters with the electrics.
Thanks for any help.
Thumbs Up Thumbs Up 1981 series 3 swb gone
1986 v8 110 station wagon current
2009 puma 110 xs utility station wagon latest addition
Post #23835 8th Feb 2010 1:00pm
K9F
Diagrams.
Landyman,
Can't really advise on availability of 'plug and play' trailer wiring. Answer probably lies in diagrams but don't have the time to look on your behalf at the moment, sorry! Nevertheless can assist with diagrams. PM sent. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #23836 8th Feb 2010 1:23pm
landyman1
p.m. received
No urgency, just grateful when time permits.
Thanks again Thumbs Up Thumbs Up 1981 series 3 swb gone
Post #23907 9th Feb 2010 9:23am
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
Like this ? Clicky One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #24023 10th Feb 2010 9:24pm
cobs
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Cairns Blue
landyman1 - in LRO this month www.mailorder4x4.com have genuine Landrover S type kit for £44.96 - don't know if this is a good price or not but may be worth a look
Post #24102 11th Feb 2010 10:29pm
landyman1
Cobs,
Many thanks for info. Yes very good price but unfortunately offer is for TD5 kit which is different than puma.
waiting to see what they come back with for puma. thanks again. Very Happy Very Happy 1981 series 3 swb gone
Post #24298 14th Feb 2010 11:02am
niglyn
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I fitted genuine LR 12N & 12S
The 12N just plugs into the connector under the wheelarch, you need to remove the plastic liner, just two screws. The 12N wiring also incorporates another connector which in turn plugs into the 12S loom this is for fog or reverse lights (i cant remember which).
The 12S loom is adjustable for 90, 110 or 130 models. The loom is 'telescopic' you pull it out to the correct length for the vehicle.
The short bit of the 12S loom runs under the wheelarch to connect to the connector on the 12N loom.
The rest of the loom has to be run under the vehicle up into the battery box. This is where you fit the relay and connect to the battery. There is a grommet in the battery box, so no holes need to be drilled.
From here a single wire comes from the battery box, under the dash board and up to a switch to the left of the radio. You need to remove the radio, pop the switch out to get to one of the wires (white/green) and scotch-lock on the single wire. This is for ignition sense. LR want you to drill a hole for this wire to exit the battery box, what I did was to run the wire out of a spare hole and extend the wire so it would reach.
All make sense? The genuine LR kit does come with instructions. It is of the new type which only has one relay. This is fine for newer caravans, 96ish onwards I think. Older caravans required a 'split charge relay' to charge the battery and a second relay which would provide power for the fridge.
With modern alternators, a split charge relay is not needed, so the relay fitted in the LRs battery box is actually for the fridge. The charging system for the caravan battery is incorporated in the caravan electrics. It takes its feed from the unswitched 12 supply from the LR, via a relay, which is controlled via the fridge feed.
Blimey, I think I have finished.
There is no great advantage buying a genuine LR 12S over an aftermarket one other than it is simpler to connect to the reverse light by simply plugging into the connector on the 12N loom. Just make sure the aftermarket loom is long enough for the LR. The genuine 12N is worth the money as it is so simple to fit, just plug it in.
Post #24341 14th Feb 2010 8:13pm
landyman1
Thumbs Up Thumbs Up
Well.
Even I can manage that. great bit of information, thanks for the trouble.
will get a 12s kit and start crawling about underneath.
let you know when I,m done.
If you don't hear back you 'll know I've crisped the wiring and too embarassed to admit it. 1981 series 3 swb gone
Post #24363 14th Feb 2010 11:14pm
GREENPUMA
United Kingdom 2007 Defender 110 Puma 2.4 SW Keswick Green
Some useful info there.
I'm just about to tackle this job. Do you have a part number for the correct 12S loom? I contacted LR and they gave me two numbers. STC8874 and LR005921, but they didn't know which was the correct one. Aparently there were less parts with the first number, so that would seem to fit with your comments re less relays etc.
thanks, Pete
Post #29149 6th Apr 2010 5:00pm
alantd
I think LR005921 is the correct one.
The other one seems to be very similar but I wonder whether it was for an older variant (Tdi?) as it is often advertised as "Defender or Discovery 1" see ebay
Smile One that started out as a 2.4 TDCi 110 XS
Post #29150 6th Apr 2010 5:18pm
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
Don't forget when you need parts contact TLO on the disco3 forum and you will get a big discount with prompt service from the most knowledgable land rover parts man in the UK Thumbs Up Original Member Pie n Pea Club.
110 HCPU Tipper
Post #29161 6th Apr 2010 6:31pm
mse
Ive just had a look for him and cant find a TLO listed...is it me? Mike
Post #29173 6th Apr 2010 10:14pm
willy eckerslike
Try this
http://www.disco3.co.uk/forum/member2459.html Original Member Pie n Pea Club.
110 HCPU Tipper
Post #29185 7th Apr 2010 5:46am
mse
Try this
Done Thanks Mike
Post #29188 7th Apr 2010 8:37am
Chunk
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Stornoway Grey
TLO sorted me out with a Cargo Barrier with discount thanks to Willy here.
Much obliged.
Post #29193 7th Apr 2010 9:38am
