![]() | Home > Maintenance & Modifications > Handbrake Light - Not Going Out |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 981 ![]() ![]() |
There is a known fault on the handbrake lever. The wire to the switch runs over the fulcrum and can rub on the arm. This can wear through and earth the circuit, which will cause the handbrake light to be on all the time. If this is what is happening to yours, then take off the rubber cover and wrap the wire with a bit of tape.
Mine had this problem, with symptoms just like yours. Merllin |
hender214 Member Since: 18 Dec 2013 Location: Sunderland Posts: 1 ![]() ![]() ![]() |
Bit of a thread revival but where can I get an new switch from also is it the same as a ford switch they look very similar?
GSLRO Member Since: 13 May 2012 Location: Tyne and Wear Posts: 499 ![]() ![]() ![]() |
Group buy! (Also in Sunderland)
My light is intermittent so was thinking switch, will take the gaiter off and have a look when I get a moment! Adventure isn't paved! |
The Part Number is: EEP191L
Avalible from LR dealer, or from places like Paddocks and BritCar. http://www.paddockspares.com/eep191l-switch.html http://www.brit-car.co.uk/product.php/8431...it_def_rrc An engine to TDi for! "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
Many thanks Gum97
![]() Will have a look at the weekend Defner parked up till whenever or whatever? Adventure isn't paved! |
