Home > Maintenance & Modifications > Handbrake Light - Not Going Out
Page 2 of 2 <12
Merlin
There is a known fault on the handbrake lever. The wire to the switch runs over the fulcrum and can rub on the arm. This can wear through and earth the circuit, which will cause the handbrake light to be on all the time. If this is what is happening to yours, then take off the rubber cover and wrap the wire with a bit of tape.
Mine had this problem, with symptoms just like yours.
Merllin
Post #178682 24th Oct 2012 6:42pm
Laurie
Mud in the system can also stop it going out.
Mine's had a new cable and a lot of cleaning since I bought it.
Light still stays on sometimes.
Post #178808 24th Oct 2012 11:37pm
hender214
United Kingdom 2003 Defender 110 Td5 HT Fuji White
Bit of a thread revival but where can I get an new switch from also is it the same as a ford switch they look very similar?
Post #291511 18th Dec 2013 9:09pm
GSLRO
United Kingdom 2002 Defender 110 Td5 CSW Chawton White
Group buy! (Also in Sunderland)
My light is intermittent so was thinking switch, will take the gaiter off and have a look when I get a moment! Adventure isn't paved!
Post #292920 24th Dec 2013 11:14am
GUM97
The Part Number is: EEP191L
Avalible from LR dealer, or from places like Paddocks and BritCar.
http://www.paddockspares.com/eep191l-switch.html
http://www.brit-car.co.uk/product.php/8431...it_def_rrc An engine to TDi for!
Post #292923 24th Dec 2013 11:36am
GSLRO
Many thanks Gum97 Thumbs Up
Will have a look at the weekend Defner parked up till whenever or whatever? Adventure isn't paved!
Post #293017 24th Dec 2013 8:07pm
Page 2 of 2 <12
