Home > My Defender > What Did You Do In Your Defender Today |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 |
Time to fit relays! LANDYWATCH
Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
1st Dec 2013 10:00pm |
mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 601 |
Top of my to-do list! - Is there a relay kit available to buy online for 2000 TD5s?
For now it's 'mend and make do' until I can find somewhere that sells a high amp toggle switch this afternoon Click image to enlarge |
2nd Dec 2013 12:02pm |
adafish Member Since: 30 Mar 2009 Location: atherstone Posts: 1385 |
should have used a dimmer switch.... Putting Dreams on Drives at JLR Solihull..
2nd Dec 2013 1:21pm |
Diablo Member Since: 26 Oct 2011 Location: Basingstoke Posts: 335 |
You don't need a kit - just go to polevolt and buy enough cable and a couple of relays and headlight connectors.
Then just spend an afternoon wiring the thing in. |
2nd Dec 2013 6:15pm |
kipperthedog Member Since: 27 Jun 2013 Location: Down South Posts: 403 |
I am loving that temporary fix!
2nd Dec 2013 6:25pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6112 |
I made one up for my 110 after the switch melted.
Used a couple of relays. Fortunately I also had an old bulkhead loom, so could chop off the socket (off of the main loom) and along with the plug off of my melted switch, had a truly plug & play loom. I used the main 12v light feed (which is the thick brown wire), to feed both relay switch contacts (pin 30), and also to feed the normal brown that goes to the headlight switch. From said switch, there is red (sidelights IIRC), and blue (headlights), each of these goes to one of the relays (onto one side of the coil, pin 86), both pin 85's can be joined together then earthed to a suitable point. So when you now switch the headlight switch, first position one relay will energise, second position, the other relay will energise. Now, there will be a red and blue floarting about, waiting for a power feed to be connected. These will connect to pin 87 on each relay, obviosuly using the correct relay for the colour wire. There is plenty of room up behind the dash to fit these two relays together with the cable. I'll take some pics of mine at some point and post them up. I did notice the lights were slightly brighter and less yellow with these relays... they're a far better switch than the cr@ppy job that comes as standard. |
2nd Dec 2013 6:40pm |
Thanks for advice, I think I'll completely redo the headlight wiring at some point and stick the relays in the battery box or under the wing - A new cable direct from battery to lights too, this way I can upgrade the bulbs
In the mean time, found a 25amp toggle switch that fits perfectly. Rated for 25 amps (300w). Has a nice solid feel to it so hopefully it will keep me out of trouble until I get time to rewire everything, the big stoke better not fail me too.. Click image to enlarge |
2nd Dec 2013 7:07pm |
I did mine the other week - stuck it in a waterproof ABS box under the N/S wing
Used the original wiring to the n/s light as the 'switch' side of the relays. Click image to enlarge |
2nd Dec 2013 7:15pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5873 |
Booked a week in Pitlochry in Jan 2014. LR content going in the 110! should be a good run of around 300miles one way! 1999 Defender TD5 110
2nd Dec 2013 7:45pm |
Will.I.AM Member Since: 16 May 2013 Location: Hertfordshire Posts: 419 |
just fitted my buckets seats from csk (killer90). Excellent deal done and the seats are really good, look just like top end corbeaus or recaros but are cheaper.
photos to follow shortly in the gallery. |
3rd Dec 2013 6:10am |
something happened to my reversing light, i suspect water and forest from the weekend ... checked the bulb, that's ok, tow electrics are my next port of call.
3rd Dec 2013 7:24am |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6315 |
found the time and courage to fix something that wasn't broke..........
Click image to enlarge fitting new hand brake cable.....hopefully will let you know later if I've succeeded? and just before I start on that I'm gonna go pick up my new map sensor to see if that makes a blind bit of difference. |
3rd Dec 2013 9:14am |
Driving along in the rain today, headlights on and working with the new switch... then the wiper arm flew off
3rd Dec 2013 8:36pm |
Early signs are map sensor has fixed engine once and for all. Hand brake cable fitted after losing one of the shoe retaining springs. Spent hours looking for it and driving round for a replacement to no avail. Ian irb offered to help but I eventually found it had only dropped behind the shoe and not sprung across the drive
Anyhow the cable is fixed just need to adjust tomorrow and refit prop. It's been an opportunity to spray some acf50 here and there while I was under the car. |
3rd Dec 2013 9:11pm |
