Home > In Car Electronics > Audio system fuse rating
ChrisD90
United Kingdom 2013 Defender 90 Puma 2.2 HT Corris Grey
I am fitting a Focal IBUS20 which includes an ISO loom that allows plug & play installation directly into the LR audio loom (with adaptor).
The manual states that in order to use this method (i.e. drawing the power from the LR audio loom) the general fuse protecting the car stereo must be 20 Amp or above.
Am I correct in thinking that the fuse protecting the stereo in a 2013 Defender is 10 Amps? 2013 Defender 90 HT
Range Rover Evoque
Post #285612 27th Nov 2013 8:09am
K9F
Yes you are correct. Everything you need to check yourself....Courtesy of our Italian Buddy Dgardel. Thumbs Up
http://api.viglink.com/api/click?format=go...5422499278 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #285625 27th Nov 2013 8:49am
ChrisD90
Thanks.
Would it be suitable to up-rate this fuse given the above, or would it be better to run a separate supply to the sub? 2013 Defender 90 HT
Range Rover Evoque
Post #285642 27th Nov 2013 9:36am
Baldinho
United Kingdom 2013 Defender 90 Puma 2.2 SW Orkney Grey
Mine (an Alpine) has a direct feed from the battery
Post #285647 27th Nov 2013 10:27am
I personally wouldn't upgrade it if it isn't that rating already. Mine is 15A and it's that rating for a reason mainly to protect the wiring but also the HU.
You'll get a much better audio quality and power transfer direct from the battery anyway.
Thumbs Up $W33T $0U7H3RN $UG4R
Post #285649 27th Nov 2013 10:40am
ChrisD90
Yep, I figured as much Thumbs Up
Would it also be better to use the 4v pre out for the subwoofer rather than speaker level?
The Kenwood has some useful functions for tailoring the subwoofer output which wouldn't be available using speaker outs... 2013 Defender 90 HT
Range Rover Evoque
Post #285650 27th Nov 2013 10:43am
Yep, use the pre out RCA connections, much better quality then and easier to fit with less wiring to do. Thumbs Up $W33T $0U7H3RN $UG4R
Post #285667 27th Nov 2013 12:40pm
ChrisD90
Thanks again, I'll definitely be taking this route Thumbs Up 2013 Defender 90 HT
Range Rover Evoque
Post #285679 27th Nov 2013 1:58pm
Hope all goes well. Thumbs Up $W33T $0U7H3RN $UG4R
Post #285686 27th Nov 2013 2:27pm
ChrisD90
Thanks, I'll post some updates on the full audio upgrade as soon as I get chance. 2013 Defender 90 HT
Range Rover Evoque
Post #285691 27th Nov 2013 2:39pm
