![]() | Home > In Car Electronics > Audio system fuse rating |
Yes you are correct. Everything you need to check yourself....Courtesy of our Italian Buddy Dgardel.
![]() http://api.viglink.com/api/click?format=go...5422499278 If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
ChrisD90 Member Since: 14 Aug 2013 Location: Middle Earth Posts: 71 ![]() ![]() ![]() |
Thanks.
Would it be suitable to up-rate this fuse given the above, or would it be better to run a separate supply to the sub? 2013 Defender 90 HT Range Rover Evoque |
Baldinho Member Since: 28 Oct 2012 Location: Surrey Posts: 123 ![]() ![]() ![]() |
Mine (an Alpine) has a direct feed from the battery
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20620 ![]() ![]() |
I personally wouldn't upgrade it if it isn't that rating already. Mine is 15A and it's that rating for a reason mainly to protect the wiring but also the HU.
You'll get a much better audio quality and power transfer direct from the battery anyway. ![]() β½οΈπ’οΈβοΈπ§°πͺ |
Yep, I figured as much
![]() Would it also be better to use the 4v pre out for the subwoofer rather than speaker level? The Kenwood has some useful functions for tailoring the subwoofer output which wouldn't be available using speaker outs... 2013 Defender 90 HT Range Rover Evoque |
Yep, use the pre out RCA connections, much better quality then and easier to fit with less wiring to do.
Thanks again, I'll definitely be taking this route
![]() Range Rover Evoque |
Hope all goes well.
Thanks, I'll post some updates on the full audio upgrade as soon as I get chance. 2013 Defender 90 HT
