Home > Wheels & Tyres > Wolf rims
Page 1 of 3 123>
peterl
1987 Defender 90 300 Tdi HT Epsom Green
Wolf rims
Two questions, will 265's fit on wolf rims and will the off set stick the tyres out any further than my standard boost rims as I am looking to fill those arches just that little bit more. If not, are there any alternative fit steel wheels that will fit the bill.
Post #279047 3rd Nov 2013 10:11am
Bows
Wales 2006 Defender 110 Td5 SW Alpine White
265 will fit, but in relation to filling the arch, I think the wolf will be similar to the boosts, If you'd like to fill the arch there are a wide range of options available, modulars, challenger, zu, etc.
Post #279058 3rd Nov 2013 11:03am
Bows
Another option is keeping the boosts and fitting 30mm spacers.
Post #279059 3rd Nov 2013 11:05am
AJS4X4
A 265 section tyre is not recommended on a 6.5J wheel rim, 7J min. Andy.
www.ajstyres.co.uk 01737 241370
Junction 8 M25 Surrey.
Post #279269 4th Nov 2013 6:52am
Interlet
United Kingdom 1998 Defender 110 300 Tdi HT Alpine White
I could be wrong but I thought the max legal size for 6.5 rim was 255. If it's not the legal max. then most people don't recommend more than 255. But I forget which it is 1998 110 300Tdi White Hard Top
Post #279274 4th Nov 2013 7:41am
As far as I know there is no specific legislation and therefore no such thing as a "legal maximum". Tyre manufacturers will however make recommendations for the minimum (and maximum) rim width for a particular tyre size (as Andy AJS4x4 states above) and there could be issues of roadworthiness and insurance if those recommendations are not conformed with.
That being said there are plenty of people who runs 265s on Wolf rims, and 285s on Boosts without any problems at all.
Post #279291 4th Nov 2013 9:08am
Interlet
Thanks blackwolf that must have been what I was thinking 1998 110 300Tdi White Hard Top
Post #279300 4th Nov 2013 10:13am
peterl
Thanks for that, no wolf rims for my 265 BGF muds then.
Back to the drawing board..
Post #279318 4th Nov 2013 11:10am
JSG
Wolf rims don't have a better offset - if you want a steel wheel with the offset to fill the arches more then try modulars. John
2011 Tdci 110 CSW XS
Post #279977 6th Nov 2013 9:56am
Defender "Wolf" steel wheels are 6.5" rims with a 20.6mm offset.
Defender Boost alloys are 7" rims with a 33mm offset.
These dimensions mean that the distance from the mounting face of the wheel to the inboard tyre seat will be:-
Wolf - 103mm
Boost - 122mm
And from the mounting face to the outboard tyre seat will be:-
Wolf - 62mm
Boost - 59 mm
(All dimensions rounded to nearest integer value mm).
So, approx 3/4" on the inside and 1/4" on the outside. which means that for the same tyre size, the Wolf rims should provide marginally more chassis clearance and better lock. Although technically it will "fill the arches" better it is debatable whether the 1/4" difference will be perceptible.
For reference, part nos for genuine Wolf rims are ANR5593 for the tube type and ANR4583 for the tubeless type.
Post #280000 6th Nov 2013 10:57am
timbar
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Slightly offtopic, but could someone explain the difference between normal-spec steel wheels, modulars and the wolf rims?
Or point a newb in the direction of same info ... I thought modulars were the same as normal spec wheels, and Wolfs equivalent to the HD spec steel wheels you can get factory-fitted? 2009 110 XS Station Wagon
Post #280007 6th Nov 2013 12:04pm
JSG
Wolf and HD are effectively the same.
Modulars are an after market wheel with round holes - wider than Wolfs and have a greater offset. John
Post #280009 6th Nov 2013 12:12pm
JSG
Or you could go for Tombraider style 8 spoke steels which are similar to the modulars. Thumbs Up
 John
Post #280011 6th Nov 2013 12:14pm
timbar
Very nice Smile Thumbs Up Although, Lara ... >squints< 2009 110 XS Station Wagon
Post #280018 6th Nov 2013 1:08pm
Mountain_man
Wales
She has definitely let herself go Rolling with laughter
Post #280035 6th Nov 2013 1:35pm
Page 1 of 3 123>
