Home > Technical > TD5 dumping PAS Fluid
red Defender
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Bonatti Grey
Mt 02 plate TD5 90 started making a noise when steering turned. This morning found large pool of fluid under drivers front wheel. Checked fluid level, well down but still some in res'. Ran engine and turned wheel, noise still there and remaining fluid seemed to become airated. Topped up res and turned wheel to try to bleed system, airated fluid started pouring from top of fluid res'. Any thoughts? Big Cry Whats broken now ?
Post #25762 4th Mar 2010 8:33am
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
Have you looked to see whether the hoses are still attached? Several folks have reported problems (me included) of PAS fluid dumping out due to a loose hose on the PAS pump. Simple fix with an 18mm spanner (although it's a Censored to reach). One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #25805 4th Mar 2010 7:18pm
cobs
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Cairns Blue
I had this on my last Disco, new steering box fixed it
Post #25825 4th Mar 2010 9:32pm
red Defender
All sorted. PAS pump gasket failure. New pump from Britparts, OEM. Fitted in no time. Dont believe Haynes, you dont have to remove the fan. Ive got a full width Ali sport intercooler which sets the rad back a bit and I had plenty of room. Recommend loosening all the bolts on the pully before removing the belt, then its easy. Thumbs Up Whats broken now ?
Post #27317 18th Mar 2010 8:42am
