Home > Technical > TD5 dumping PAS Fluid |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
Have you looked to see whether the hoses are still attached? Several folks have reported problems (me included) of PAS fluid dumping out due to a loose hose on the PAS pump. Simple fix with an 18mm spanner (although it's a to reach). One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition |
4th Mar 2010 8:18pm |
cobs Member Since: 12 Jun 2008 Location: North Yorkshire Posts: 336 |
I had this on my last Disco, new steering box fixed it
4th Mar 2010 10:32pm |
red Defender Member Since: 11 Feb 2008 Location: Cornwall Posts: 76 |
All sorted. PAS pump gasket failure. New pump from Britparts, OEM. Fitted in no time. Dont believe Haynes, you dont have to remove the fan. Ive got a full width Ali sport intercooler which sets the rad back a bit and I had plenty of room. Recommend loosening all the bolts on the pully before removing the belt, then its easy. Whats broken now ?
18th Mar 2010 9:42am |
