Home > My Defender > What Did You Do In Your Defender Today |
Knot Yet Member Since: 01 Mar 2010 Location: West Sussex Posts: 197 |
Thanks K9F - very interesting and as you say does look good Defender 110 Puma Utility XS
7th Mar 2010 7:15pm |
Cibit Member Since: 26 Oct 2009 Location: Northumberland Posts: 424 |
Used the air con 59 2.4 110 XS Utility
55 TD5 110 CSW Special Vehicle |
8th Mar 2010 2:26pm |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2646 |
Went to the Land Rover Experience course on Saturday. SWAMBO did the driving
8th Mar 2010 6:06pm |
JMS Member Since: 05 Mar 2010 Location: Isle of Wight Posts: 40 |
Reversed over my Iphone....
9th Mar 2010 5:54pm |
willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789 |
Well done at last some one with some sense, lets hope a few more follow suit and rid our society of that Spawn of Satan the iphone. Original Member Pie n Pea Club.
110 HCPU Tipper |
9th Mar 2010 6:23pm |
+ 1^10 |
9th Mar 2010 6:29pm |
Nice pics Naks,
Good example of articulation capabilities! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
10th Mar 2010 7:50am |
Yes, and you know what happened after that? See http://www.defender2.net/forum/topic2749.html?highlight= |
10th Mar 2010 7:54am |
I remember looking at that thread but never tied the two together! With the bush dislodged that's how you probably achieved such impressive articulatory pictures!
Sorted now I trust? If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
10th Mar 2010 8:44am |
Actually not, the banging noise only started after we finished the trail and were heading back to lunch. The articulation must have started the dislodging? Yep, all sorted, I crawled under the landy, unbolted the mounting, pushed the rubber back in, and bolted everything back. I also checked the other mounting, and the bolts were not as tight, since I could tighten then further - probably been like that since it left the factory. |
10th Mar 2010 8:51am |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 |
Today, I finnaly got my @rse into gear and fitted my Defender2.net sticker (only taken 5 months ). I think it finishes the rear end off well
Glyn :sheep: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Last edited by Glynparry25 on 11th Mar 2010 10:00pm. Edited 2 times in total |
11th Mar 2010 9:56pm |
TACK Member Since: 26 Apr 2009 Location: Essex Posts: 1045 |
nice sticky rear glyn
11th Mar 2010 9:58pm |
Fitted my cargo barrier, nearly gave up twice. No wonder L/R insist it is a long job (forget how many hours) the tolerances are rubbish but it took me about 3 in total with some profanity and grazed knuckles
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge feels secure. Now off to dig out a MOLLE pouch for my jetboil and brew kit :thumbsup: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated 59 2.4 110 XS Utility 55 TD5 110 CSW Special Vehicle |
14th Mar 2010 1:38pm |
Yep they label the brackets LH and RH but don't tell you which end they where looking from, they can't be wrong then Original Member Pie n Pea Club.
110 HCPU Tipper |
14th Mar 2010 1:51pm |
