Home > My Defender > What Did You Do In Your Defender Today |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678 |
Time for new glasses Brendan .... |
12th Aug 2013 9:36am |
ttuck3r Member Since: 03 Feb 2013 Location: Dunning Scotland Posts: 277 |
Got my Defender back from Strathearn Engineering today all fixed up, after me snapping the bolts off the EGR very happy Thanks to the Lads for getting to it so quickly..
13th Aug 2013 9:25pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20299 |
How'd you manage that? ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️ |
14th Aug 2013 9:53am |
Les Brock Member Since: 20 Mar 2012 Location: Stroud, Glos Posts: 151 |
I'm ok I have lockable flush bonnet pins The main reason for me fitting them TBH was to get rid of the silly plastic insert Regards Les |
14th Aug 2013 10:19am |
WarPig Member Since: 04 Dec 2009 Location: Sheffield Posts: 1748 |
I'd lime to know this as well. Do they stop the bonnet being tilted back and then lifted straight out? |
14th Aug 2013 1:00pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17351 |
Yes, you would need tools to remove the bonnet, so it slows the villains down and makes your neighbour's Defender an easier target. It is also easy enough to make it very hard to remove these hinges - use one (or more) shear nut to secure each hinge to the bonnet, and use a shear nut and socket head cap screw with Loctite to attach the hinge to the bulkhead. Then glue a ball-bearing in the socket of the capscrew. |
14th Aug 2013 2:08pm |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 |
Drove a beautiful track across valley and hills in the Tarn region near Galliac. BM52
14th Aug 2013 2:50pm |
YeomanOfTheBar Member Since: 04 Nov 2012 Location: North Notts Posts: 206 |
Got my truck back from Waxoyling at Tim Fry's in Cheltenham 2013 Defender 110 XS DCPU
2016 Ford Mustang 5.0 V8 |
14th Aug 2013 8:07pm |
Re-attached my newly powder coated side steps using nice, shiny stainless nuts and bolts to my recently dinitrolled chassis, proving that my OCD is alive and well
I did, however, run out of rivets to re-attach the rubber treads Click image to enlarge Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
14th Aug 2013 8:11pm |
PK1 Member Since: 19 Oct 2012 Location: Gloucestershire Posts: 96 |
Took Landy for its MOT today and it passed with flying colours
Defender 110 TDCi XS SW Range Rover Sport HSE |
14th Aug 2013 9:51pm |
theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862 |
today i righted a few oddities first off was the traditional land rover wonky steering wheel, which is now slightly less wonky but towrads the O/S now instead. love land rover quirks !
Click image to enlarge Click image to enlarge then i found the tweeter that was pushed into the dash by the 9ft logs mother in law had me collect. at which point i saw the opportunity to claim "see i told you a land rover made sense" to which silence was my reply Click image to enlarge Click image to enlarge then i broke into the dash board to refit the cable that had unclipped itself from the recirculate switch for the fans, the cable had become rather bent which caused it to pop off. so straitened it up with my man hands and sorted ! Click image to enlarge Click image to enlarge a good day however i want to re hang every single door as each of them have there own special quirks, any one got any tips? also on 110 CSW does any one else get splashed in the face when you close the rear passenger doors in and after teh rain ? |
15th Aug 2013 4:51pm |
Been cleaning the chassis up all afternoon. Damned hard work but got to be done. In better condition than I though but that's a good thing! Better to underseal early than too late.
15th Aug 2013 6:51pm |
Bolted the mud flaps back on today. Again, newly powder coated and using stainless fixings:
Click image to enlarge You can just make out the neoprene isolating pad between the bracket and underside of the rear wing. There's another on the inside too, which together serve to introduce a degree of flexibility. This is to prevent the work hardening of the wing lip that leads to fracturing of the aluminium. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
15th Aug 2013 7:32pm |
Mr Baldylocks Member Since: 15 Jul 2010 Location: Nearer my home than yours. Posts: 487 |
Now Martin has helped with this here are a few pictures of my pride and joy
I hope you like them. Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Life is one big adventure, that's why we have the vehicle for the journey. |
15th Aug 2013 7:34pm |
