![]() | Home > In Car Electronics > The definitive Defender ICE thread |
They'd only be needed if you want to make use of the functions that they relate too. The 'reverse gear signal input' will be for a reversing camera and the 'mute' will clearly be if you are using some sort of fixed hands free system. I'd hazard a guess that the 'parking brake' connection is to do with watching video and only allowing it when you've stopped. 'P.cont' will be a permanent live feed so you can use it with the ignition off and probably enable it to keep radio pre-sets. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
jont Member Since: 02 Apr 2011 Location: Aylesbury, Bucks Posts: 242 ![]() ![]() |
Hi - they are Kenwood KFC-E1064's ... got them from justkenwood.co.uk They are a direct fit - although you will need to cut/shape/Dremel the back lip to the speaker card to fit the retaining clips for the new, slimmer screws they supply ... took about 5 mins once I'd carefully done the first one ! I also got some KFC-ST30 tweeters and a KSC-SW01 active subwoofer to fit next ![]() Jon |
Thanks Darren - I'd sort of figured what they were - was really asking if there is something specific on the Defender loom to connect them to ? ... am thinking of getting a reversing camera so that would get hooked up - what would the parking brake connect to ? cheers Jon |
Either the switch on the handbrake or the feed to the brake light on the dash. I think the latter will be more difficult though, as it'll be integrated into the instrument pack. Darren
adseybear Member Since: 08 Oct 2009 Location: Vancouver, Canada Posts: 262 ![]() ![]() |
So how does this fit in a Td5 dash? 2003 Defender 90 Td5 CSW Belize Green - "Betty" 1958 Series IIA 109 Station Wagon - "Randolph" - Awaiting Restoration 2019 Jeep Wrangler JL Rubicon - SOLD 2006 Volvo V70 D5 - Ocean Race Edition, SOLD 2003 VW Passat Estate 1.9TDI - SOLD 2008 BMW 320D M Sport Estate - SOLD 2001 Defender 90 Td5 Hard Top - SOLD |
adseybear ... hopefully by hacking away at the dash cover as described in http://www.defender2.net/forum/topic22304.html ... see my post at bottom of first page
![]() rgds Jon |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20641 ![]() ![]() |
I thought this too as it's a 2DIN HU with a 1DIN slot. As he saidd I assumed he would enlarge it. ![]() β½οΈπ’οΈβοΈπ§°πͺ |
pjb Member Since: 08 Apr 2009 Location: Sunny Oxford Posts: 1244 ![]() |
in my last TD5 an XS I bought the mud dash & just resprayed the whole thing black ![]() |
Did you buy component speakers?? If you did you will have 4 crossovers (2 per side/speaker) which enable you to fit the supplied tweeters, not sure how you would correctly fit tweeters without crossovers as crossovers divide the signal from the H/U into low frequency (woofers) and high frequency (tweeters). Of course anything is do-able,but would have thought your tweeters gonna take a beating from the low range frequency. |
They aren't components AFAIK.... Mine are currently connected to the standard LR loom. Although not taking the full power they can handle they work well. Because they are so powerful also and high quality it doesn't worry me really running without a x over. The only way other than that would be to Amp them (not sure I would want that because they'd be so loud) and then you could use the x' over's as the power output will be there and take the signals and hardwire them from the original tweeter feed.
All depends on what power they are too but I don't really see the point in screamingly high power on high frequency music. All it will do is make you want to turn it down because it's so loud and pretty much damage your hearing I would imagine if you went to OTT with it. I have to use mine in this way for now anyway as the HU power output isn't enough to power them anyway. Only get a whisper out of them. TheThunder Rollsπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1434 ![]() ![]() ![]() |
I quite like the look of that, and it has DAB. Still waiting for an Alpine with 3 4v preouts. Do you have a modle number at all and I can look up specs? |
We'll i got my replaced tweeters fitted today and x overs fitted this time too an wow!
![]() ![]() β½οΈπ’οΈβοΈπ§°πͺ |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 ![]() ![]() |
Jont you have a PM
