Home > Wheels & Tyres > Locking wheel nut - Stuck! |
Not sure if this is any good for Defender nuts?
http://www.screwfix.com/p/laser-emergency-..._container Or... http://www.machinemart.co.uk/shop/product/...emover-2pc This one looks quite nifty... http://www.lockingwheelnutremover.co.uk/ Regards Pete An engine to TDi for! "Land Rover- Proudly turning drivers into mechanics since 1948" |
20th Jul 2013 8:34pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5861 |
Interesting but
"4 x 38mm ½" drive locking wheel nut removers (17, 18.5, 21.5 and 26mm) and a metal storage case." 26mm ? Landy ones are 27mm. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
20th Jul 2013 8:37pm |
Ah, maybe that's not such a good solution then! An engine to TDi for!
20th Jul 2013 8:41pm |
Oh, on another note, I've got a set of 4 locking nuts that you can have if you want them An engine to TDi for!
20th Jul 2013 8:42pm |
NickEJ Member Since: 24 Nov 2012 Location: Ljubljana Posts: 152 |
If I understand your problem correctly, the wheel nut with have a letter stamped on it. Just tell the dealer the letter and they'll sell you the right socket. I think, from memory, that there are about 12 variations.
20th Jul 2013 8:47pm |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 |
If you have the standard fitment locking wheel nuts there should be a code stamped on the removel tool,your local main dealer will be able to supply a replacement. 2005 Td5 90 XS
Steve |
20th Jul 2013 8:49pm |
Cheers, I will have a look for a marking on the removal tool. 1999 Defender TD5 110
20th Jul 2013 9:25pm |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 |
As Lou says LANDYWATCH
Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
20th Jul 2013 9:43pm |
Macpaul Member Since: 25 Mar 2013 Location: SW Surrey Posts: 439 |
Yup as above, there should be a letter stamped.
Apparently dealers sell loads of them as they won't withstand the windy guns/impact wrenches that Kwik Fit etc use and they shatter all the time. |
21st Jul 2013 7:05am |
I think that's what's happened but not sure when! 1999 Defender TD5 110
21st Jul 2013 7:52am |
Landlord Member Since: 27 Oct 2009 Location: Hampshire Posts: 582 |
Mine went on my RRS recently. Had to have them drilled out, £160 later all removed
Lockers had corroded over time so that the security socket was ineffective. Now don't have locking wheel nuts - much easier. 2007 TD5 90 Hard Top |
21st Jul 2013 2:34pm |
taffrican Member Since: 14 Jan 2011 Location: Living room Posts: 624 |
Same with the wife's D3, my adaptor went missing, I went to see the mechanic's at Stratstone Cheltenham and they gave me one of their spares for free, he said loads of them get "left" behind after work being done (which I suspected happened to mine, until wifie found it in a box she used to remove stuff from car proir to service ) Optimists say the glass is half full..
Pessimists say the glass is half empty.. Engineers say the glass is twice the size it needs to be! Last edited by taffrican on 21st Jul 2013 3:23pm. Edited 1 time in total |
21st Jul 2013 3:23pm |
^^Well, some people will decide to drive Range Rovers An engine to TDi for!
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2661 |
Just hammer a very slightly smaller socket on. Worked for me when I bought a 110 with locking nuts but no key, got all five off no problem and threw the stupid things away.
21st Jul 2013 3:38pm |
