Home > Puma (Tdci) > Power upgrade
Page 3 of 3 <123
Mad Cow
England 2007 Defender 90 Puma 2.4 HT Zermatt Silver
Harley like a Land Rover?
No more like my CCM
British built
Dubious build quality
Has had several different owners over the years
Suspect reliability
Lously aerodynamics
But
Does what it was designed without question
Easy for the home mechanic to fix and modify
Puts a huge grin on my face everytime I go out on it!
OK so I have a Beemer too, as does the Mrs. (F800GS & F800R)
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  MAD COW
2007 90 Hard Top - 2009 BMW F800GS - 2002 CCM 604E Dual Sport
Project90
Post #17998 8th Nov 2009 12:07pm
K9F
Power Upgrades!
dgardel wrote:
But How many KW after BAS remap????? and torque????
I am a new member and this apart from my 'Introduction' is my first post. I have had an Autologic ECU upgrade carried out on mine, power went up from 119BHP to 149BHP and torque from 314NM to 393NM. The 82-84MPH limiter has also gone as part of the upgrade. (Other upgrades can advertise extra cost for removal of the limiter). Here is the linky thingy for those that may be interested or have a different Land Rover together with graphs.
http://www.james-french.co.uk/power-upgrades.asp
The drive is awesome, I also capped it off with an ITG Performance Filter and the induction noise is great!
It was also explained to me that many 'plug and play' variants of upgrade merely 'fool' the ECU into thinking the fuel inlet boost pressure is lower than it effectively is;- The result is that you have a power upgrade that is achieved merely by throwing more fuel at the engine. I have noticed an approximate 15-20% increased fuel consumption but the temptation to 'rag it' is never far from my mind. In hard driving conditions the consumption is as it was prior to the reprogramme. With regards to the garage overwriting your upgrade you get a unique number that allows you to get the programme reinstalled by any Autologic dealer at minimal or indeed no cost at all in that eventuality. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #18227 12th Nov 2009 12:25pm
badwookie
Kuwait 2010 Defender 90 Puma 2.4 XS CSW Zermatt Silver
Re: what about upgrading
cilkorules wrote:
what about upgrading the turbo slightly larger and intercooler slightly larger then give the computer a tune on the dyno machine,
or you could change the gearing inside the differentials to 3.73:1 giveing a better take off again.
the defender should have a v6 twin turbo diesel engine idealy, thats my opinion or modification and my idea(c)
What do you guys think about changing the gearing inside the diffs. for better take off ? good ? bad ? indifferent ?
Post #25121 25th Feb 2010 4:52pm
Gav110
Australia
Anyone tried combining BAS with an intercooler upgrade? Would it effectively need to be re-tuned to get the most from it?
I had the larger intercooler, 3" exhaust AND chip on my TD5 - it was incredible.
Don't really want to 'hack' my new Puma too much though, so if the BAS box alone is the business then that'll do ! Gavster
2010 Puma 110
Post #25274 27th Feb 2010 6:07am
Page 3 of 3 <123
