Home > Maintenance & Modifications > crystal headlamp, does brand matter ?
theorangebandit
I would love ! Some led headlamps however I don't have that muchto throw at lights. So I decided to go for crystal lamps. There ar many different brands out there I feel like I can trust and expect wipac to be the best however want to know if there's any other brands
I will couple the lamps with better bulbs and some new stainless bezels. Much needed ! Matching screws too
I did set my sights on projected lamps at first but only found motorbike ones. Therefore not having the lamp kick up s not ideal although I would be able to legally fit HIDs with a projector bulb.
I tried several different searches and none had the answer to my question forgive me if its been aske
Post #250946 12th Jul 2013 6:49pm
db950
United Kingdom 1997 Defender 110 300 Tdi HT Nato Green
I have the wipac crystals fitted (got them from Flatdog) with osram nightbreaker bulbs and can't fault them.
Very bright on dip and main, infact you can't really see any difference when I switch my warn driving lamps on! 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
2014 Discovery 4 SE Tech
Instagram @the110camper
Post #250969 12th Jul 2013 8:22pm
theorangebandit
Nothin' like a good review ill prob go for the wipacs cheers
Post #250978 12th Jul 2013 8:57pm
SS bezels Wipac Crystals and Philips Extreme 90% for me. Thumbs Up Thumbs Up No Guts, No Glory.
🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª
Post #250993 12th Jul 2013 9:54pm
Bev
Scotland 2003 Defender 90 Td5 CSW Oslo Blue
Wipac crystal and Osram night beakers for me. Don't even need extra driving lights even on the B roads in the north. No point lighting up 400 yards in front when the roads take a twist and turn every few metres..
Bulbs were £12 and the wipac bowls around £30.....
Post #251003 12th Jul 2013 10:46pm
lambert.the.farmer
England 1998 Defender 90 300 Tdi PU Rutland Red
Wipac and ring 100%. Can't fault them. Rhubarb and custard let fly with their secret weapon.
Post #251013 13th Jul 2013 5:56am
theorangebandit
Wipac certainly has a good rep
Post #251014 13th Jul 2013 6:05am
BigWheels
I uprated to Wipacs too. Fitted Philips H4 (silver tips). OE were OK on main beam but these are much better dipped. I think the Wipacs actually make the front look nicer. Due to having a clear lens, when the sun shines on them, the reflectors reflect it back so strongly I've been flashed by motorists who have thought I've left the lights on!
Can anyone recommend good light guards, that are strong & actually protect headlights without reducing the light too much? Whenever I see old Series cage type protectors, they always look hardier than the sleeker more modern ones. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #251066 13th Jul 2013 11:09am
I think the same too. The glass lenses just look a bit dated to me. No Guts, No Glory.
Post #251068 13th Jul 2013 11:11am
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
I have the Wipac crystal bought from Paddocks for £27 I think in my 110 over here in Germany. They obviously throw to the left, but I will be fitting the same lights when I return to UK later this year. Good lights for the money and certainly good enough for a Defender. I use Phillips bulbs in mine, but cannot remember which particular type. For the money you can't go wrong.
Post #251069 13th Jul 2013 11:22am
theorangebandit
yea they certainly aren't at all expensive, and I too agree thy look much neater, no idea why they aren't fitted as standard im sure that a new headlamp from land rover will cost the same if not more.
Post #251080 13th Jul 2013 12:47pm
mobilecentre
Wipac Thumbs Up
Post #251100 13th Jul 2013 4:49pm
Grouse
Crystals and night breaker. Seriously you do not need any more on a defender. Unbelievably cheap and fantastic illumination.
Post #251123 13th Jul 2013 7:32pm
BigWheels
Found my Philips bulb case. They are X-treme Vision H4. More expensive than Ossies, I bought a pair of each. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #251147 13th Jul 2013 10:12pm
Martin
Site Admin
I must be alone in not liking the style of the crystal headlights Confused  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #251148 13th Jul 2013 10:14pm
