Home > Maintenance & Modifications > Installing a aux power socket in the rear
Page 3 of 11 <123 4 ... 91011>
TheWarden
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
if it's still the, the mod can be done, but just requires a bit more work.... something to investigate I think as a rear aux socket would be very useful 2013 Aintree Green 110 Station Wagon SX
Post #247834 30th Jun 2013 5:42pm
mobilecentre
Purple wire can be seen on right hand side of plug
Post #247838 30th Jun 2013 5:47pm
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
ChrisCM wrote:
Thanks for the info, just ordered a few sockets to scatter about the vehicle.
One question though - those pesky trim clips/screws, before I get stuck in with my screwdriver or panel remover, how do these ones work, is it just a case of unscrewing the centre pin, removing it then popping the bit that's left with he panel popper? Or is there some other trick Confused
Thanks
Chris
I normaly try the philips screwdriver, if that fails panel popper between the head and and the rest, they normaly just pull out. Mine have been out more times than enough the last two weeks that they now know whats coming. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #247857 30th Jun 2013 7:00pm
Martin 01
Just fitted a couple of 12v sockets in to mine ready for the summer.
Just don't know why land rover do not fit them as standard.
Thanks for the tip on finding the cable.
Thumbs Up
Post #249604 6th Jul 2013 7:32pm
DiscoStu
United Kingdom 2013 Defender 110 Puma 2.2 SW Santorini Black
mobilecentre wrote:
The whole wire has not been deleted just the two way connector that goes "nowhere" has been removed from the loom the cable still continues from Fuse 2 under the seat through to the rear loom and terminates in the towing electrics connector in the rear wheel arch.
Will removing the rear speaker panel (drivers side) expose this loom, or do I need to look elsewhere? My Disco 'best bits'
Defender 110 XS CSW 2013
Post #249653 7th Jul 2013 5:51am
Paul55
England 2008 Defender 90 Puma 2.4 XS CSW Santorini Black
Thumbs Up removed my speaker and the loom was just to the left hand side. Cogito ergo sum
Post #249675 7th Jul 2013 8:18am
DiscoStu
Thank you Thumbs Up My Disco 'best bits'
Post #249680 7th Jul 2013 8:33am
Swollock
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Bonatti Grey
Thanks for this, was about to try and fit one myself. Save me no end of trouble as was looking at running cable into the back.
Tony 2008 Defender 110 XS CSW
Volvo S60 T8
Triumph 1200 Rally Explorer
G0UBX
Post #249696 7th Jul 2013 9:39am
Martin 01
Which fuse is it connected to ?
Think I've just blown it testing my fridge out.
Plugged fridge in & nothing until ignition on.
Ran for a short while then went off.
No power now at the sockets.
Any ideas ?
Martin
Thumbs Up
Post #250030 8th Jul 2013 7:02pm
Martin 01
Forgot to say its a 2002 110 CSW.
Looked at all fuses and they all seem ok.
I'm a little lost.
Any answers ?
Thumbs Up
Post #250097 8th Jul 2013 9:23pm
ericvv
Post #250126 9th Jul 2013 4:43am
Martin 01
ericvv wrote:
Martin,
The purple wire goes back to fuse 2 (20Amp) under the RH side seat. It also protects the towing socket. At least that is so on a Puma.
Eric
I have taken a look this morning Eric and found a blown fuse under the drivers seat.
It was a 15amp one.
I have replaced that one but still no power at socket.
Checked all other fuses and they are all ok.
Any other suggestions ?
Thumbs Up
Post #250134 9th Jul 2013 6:33am
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Recheck fuse 2 which should be 30amp and power accessory wiring to rear, trailer power and interior lights. The only 15amp fuse under the drivers seat is fuse 6 Alarm system, according to Dgardels Users Handbook for a td5. Thumbs Up Whistle LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #250302 9th Jul 2013 7:37pm
Martin 01
Welshgas,
Checked that fuse & all is ok.
Interior lights all ok.
Plugged my caravan into the towing socket & all is working.
I'm a little baffled.
All fuses are ok after checking.
Any ideas ?
Post #250308 9th Jul 2013 8:02pm
WelshGas
Some in-line fuse maybe?
Use multimeter to check continuity of +tve or earth. Thumbs Up LANDYWATCH
Post #250314 9th Jul 2013 8:11pm
