Home > Maintenance & Modifications > what a tool.....
Caterham
what a tool.....
http://www.mcdonaldlandrover.co.uk/parts/p...dqjel4ml96
can anyone recommend an alternative ?
and am I right in thinking the nuts / bots are 9/16" ?
thanks
Post #247106 27th Jun 2013 7:30am
the thinner shaft part of the tool allows you to get to the nuts more easily .. make life easier
Post #247108 27th Jun 2013 7:33am
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
Not sure if you want the same tool from a different supplier, but there's one here...
http://www.rimmerbros.co.uk/Item--i-RX1021BP
Simon
Post #247110 27th Jun 2013 7:47am
Caterham
thanks for that.
and as I though 9/16.
that leads me to think my spanners aren't too great as I've slightly rounded one of my bolt heads using a 9/16?
(must get tool and some nice shiney new nuts / bolts).
thanks
Post #247113 27th Jun 2013 7:54am
couplands
I just bought a Professional Socket Set from Halfords, they seem to get great reviews. Includes a set of spanners too...although metric, so may not be ideal for the prop shaft nuts..;-(
http://www.halfords.com/webapp/wcs/stores/...ogId=10151
Simon
Post #247117 27th Jun 2013 8:04am
jst
Difflock sell prop shaft tools before. yes 9/16th heads. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #247121 27th Jun 2013 8:29am
I use one of these:-
Snap on universal socket.
Works a treat, but isn't the cheapest solution.
Strictly speaking the fastener is 3/8" UNF and the head size is 9/16" AF (which is close to, but not the same as, 14mm).
Post #247160 27th Jun 2013 11:26am
Martin
Site Admin
Buy a genuine Japanese Koken one rather than the Britpart copy.
Like http://www.ebay.co.uk/itm/380395342420 (3/8" drive)
Or http://www.ebay.co.uk/itm/160701865951 (1/2" drive)  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #247161 27th Jun 2013 11:33am
Caterham
thanks Martin.
Post #247169 27th Jun 2013 11:50am
Caterham
simon,
thanks for the suggestion re the halford kit - gone one and great.
martin (or anyone else)....
can you confirm that buying one of these
is worth it. ie is it far better than simply trying to use an ordinary socket set such as the halfords pro set as above.?
many thanks.
Post #248235 2nd Jul 2013 7:25am
jst
errrrrr
yes much better, hence they are available and all the recommendations/posts above to different ones.
have you tried one? or tried it without one at all? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #248241 2nd Jul 2013 7:35am
Caterham
don't it without....
didn't really too much not knowing for sure what size socket / spanner I was supposed to be using Shocked
off to order one up
many thanks
Post #248257 2nd Jul 2013 8:15am
x-isle
Have to admit, when I was racing a few years back I was desperate to get hold of a certain socket size that I didn't have (can't remember what size) and the only option was Halfords.
There was a special offer on their 170 (I think) Pro socket set. It was so cheap I bought it. I didn't think it would last too long.
The ratchets didn't last too long on the drives apart from the 1/2" is still going strong, but the sockets (and indeed the spanners) lasted, in fact, I still use them today and are still like new.
They lasted longer than the "Snap-Off" ones I had. Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #248262 2nd Jul 2013 8:32am
Likeomg
my father has a slight obsession with tools... polishes his spanners from time to time etc...
has a full snap on kit, and i mean everything there is, whenever the snap on man is around he is shocked at what we have... does come in handy
best kit ive ever used, ratchet screw driver must be 25 years old and still going, i think everyone should own a snap on ratchet or 2, and a socket set... out of the 8 ratchets we have, 1 has only ever failed (after about 10 years of work), and it got serviced and came back like new, the 3 we bought last year just had a good workout replacing a lot of bits on a td5 last year
Post #248267 2nd Jul 2013 8:45am
x-isle
Weird how peoples perceptions are different. I didn't get on with Snap On and in the Paddock, it was nick named Snap Off due to the amount of failed ratchets that people where getting.
I use Teng for ratchets and they haven't let me down (yet). Craig Rogers
2007 Puma 110 XS
Post #248270 2nd Jul 2013 8:50am
