Home > Td5 > Nanocoms |
Have a look on their web site, there were full instructions in PDF format.
I had one on my td5, easy to use, can read and reset faults, change settings on alarm, abs etc. nice units. |
19th Jun 2013 3:38pm |
johnnyd Member Since: 13 Apr 2013 Location: Chippenham Posts: 1006 |
Yeh
Nanocom has arrived 2008 TDCi 2.4 XS CSW |
20th Jun 2013 1:57pm |
Oooh only one error reported
Airflow circuit logged low.........now what does that mean Does a list of error descriptions exist anywhere? JD edit......i found this Mass air flow (MAF) sensor/volume air flow - voltage low -> Probable cause: Wiring short to earth, supply voltage, earth connection, MAF sensor, ECM 2008 TDCi 2.4 XS CSW |
20th Jun 2013 6:11pm |
Ah.....still getting to grips with the Nanocom, found these other errors, given i dont have aircon (1998) do i need to do anything, is it just a reporting error?, the gearbox fault worries me though ? Although i doubt I have ABS fitted on a 1998?
NANOCOM - TD5ENG.APP - TD5 ENGINE fault file (10,1) AIR CONDITIONING FAN DRIVE OPEN LOAD, (LOGGED). (10,4) GEARBOX / ABS DRIVE OPEN LOAD, (LOGGED). (10,5) AIR CONDITIONING CLUTCH DRIVE OPEN LOA D, (LOGGED). (14,1) AIR CONDITIONING FAN DRIVE OPEN LOAD, (CURRENT). (14,4) GEARBOX / ABS DRIVE OPEN LOAD, (CURRENT). (14,5) AIR CONDITIONING CLUTCH DRIVE OPEN LOAD, (CURRENT). Many Thanks JD 2008 TDCi 2.4 XS CSW |
22nd Jun 2013 10:56am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5729 |
No need to do anything for those faults.
Andy |
22nd Jun 2013 12:35pm |
Thanks Andy.....I thought as much, but still very new to this
22nd Jun 2013 12:40pm |
Is the new one like my old one where you need codes to go into further modes?
It seems like a silly system to me, like buying a house and only being given the keys to one of the doors, why not just allow all functions to work Andy |
22nd Jun 2013 12:45pm |
Hi Andy
Unfortunately yes......I got 2 codes, codes 1 and 2 which is for defender and ABS I think? It's rather odd, just want to make more money I guess? JD 2008 TDCi 2.4 XS CSW |
22nd Jun 2013 12:53pm |
Can you switch units in the nanocom, the speed is either misreading, or is in Kilometres?
7th Jul 2013 12:04pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6098 |
The speedo on my nanocom never seems to correlate to the dash speedo, although I think it just reads the pulses from the transducer, as opposed to converting to "speed"
7th Jul 2013 1:20pm |
It seems to be in kph and oly accurate for 7.5 types according to this.....
http://web.nanocom.it/news_f.cfm?articolo=499 JD 2008 TDCi 2.4 XS CSW |
7th Jul 2013 6:45pm |
But doesnt that give you the idea on how to calibrate your nanocom, i.e. big tyre/7.5 tyre and also 1000 revs = 1mile. I take it these notes are for the later nanocom evo and not the original nanocom 1
7th Jul 2013 7:16pm |
can anyone tell me where the 'record fuelling' function is on the evo, i have read pdf's and instructions but cant see it anywhere, i need to go for a couple of minutes drive and record whats going on
25th Jul 2013 10:40am |
Found it......its the 'save' icon 2008 TDCi 2.4 XS CSW
25th Jul 2013 4:03pm |
