Home > Maintenance & Modifications > Alarm remote receiver wire extension.
Sign Up
(75)
User Registered Confirmed
MUF3rd Dec 2009 10:21pm
foxkilla4th Dec 2009 7:43am
parktag4th Dec 2009 9:13am
Ads904th Dec 2009 9:23am
K9F4th Dec 2009 10:52am
marks4th Dec 2009 1:59pm
Fjord4th Dec 2009 6:12pm
ponamore4th Dec 2009 6:39pm
TJ1014th Dec 2009 9:31pm
dgardel4th Dec 2009 9:45pm
Mad Cow5th Dec 2009 8:28am
Eduardo5th Dec 2009 12:25pm
Grockle5th Dec 2009 12:32pm
nicks5th Dec 2009 1:46pm
double cab happy5th Dec 2009 4:17pm
dm_td55th Dec 2009 8:10pm
Martin5th Dec 2009 8:40pm
LR09WA6th Dec 2009 10:39am
Defender SVX6th Dec 2009 11:11am
discoch16th Dec 2009 2:12pm
ken6th Dec 2009 4:21pm
brocklebank6th Dec 2009 4:46pm
jamesbond0077th Dec 2009 8:26am
log117th Dec 2009 3:25pm
Jonnythiefonepost7th Dec 2009 7:32pm
JohanH7th Dec 2009 9:20pm
cobs7th Dec 2009 10:40pm
Sticky8th Dec 2009 6:59am
peanutbob8th Dec 2009 11:13pm
totoD1109th Dec 2009 12:56pm
sib9th Dec 2009 3:33pm
Laurie10th Dec 2009 6:05pm
Michaels Defender10th Dec 2009 9:39pm
Ricky Chianese11th Dec 2009 10:00am
alantd13th Dec 2009 12:20am
cradgebank15th Dec 2009 4:06am
Eric L16th Dec 2009 3:45pm
gtveloce6516th Dec 2009 4:44pm
RRS1316th Dec 2009 10:59pm
Gabriel Boff31st Dec 2009 5:16pm
Fandango8th Jan 2010 1:39pm
silverpig8th Jan 2010 6:14pm
amtravic110th Jan 2010 8:39am
nico7610th Jan 2010 6:08pm
solmanic12th Jan 2010 2:34am
jst12th Jan 2010 10:20am
The Boy20th Jan 2010 12:45pm
ian96421st Jan 2010 9:44am
Hans21st Jan 2010 6:21pm
hornet22nd Jan 2010 10:46am
merebrowpaul23rd Jan 2010 11:37am
gumdrop25th Jan 2010 6:02pm
Naks26th Jan 2010 7:53pm
munsterlandy26th Jan 2010 9:46pm
4Seasons20th Feb 2010 8:47pm
custom9022nd Jul 2010 10:32am
mse22nd Jul 2010 8:09pm
bpman25th Jul 2010 3:16pm
Mick Clark2nd Sep 2010 6:15am
craigyboy14th Sep 2010 7:34pm
Shax6th Oct 2010 11:07am
BigMike28th Oct 2010 11:04pm
szracer5th Nov 2010 8:48am
TC23rd Nov 2010 8:56pm
haworthj26th Nov 2010 3:22pm
110SEB26th Nov 2010 8:35pm
toshers27th Nov 2010 6:00am
Peter Td427th Nov 2010 4:41pm
StephenM27th Nov 2010 4:56pm
BIGFOG28th Nov 2010 8:21am
Finnskogingen12th Dec 2010 9:15pm
biffabacon679th Mar 2011 6:40pm
jont12th May 2011 6:29pm
flinty9925th May 2011 11:23pm
3 Lions23rd Jul 2011 8:55am
Page 5 of 8 <12345678>
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
The 'issue' is the short operating range. That's true of all Defenders that have remotes. The fix will likely work on all as well (I assume it's the same unit). One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #22977 26th Jan 2010 9:39pm
Naks
thanks for the info.
Maybe I'm being dof this morning, but what is the registration on this topic all about Question
Post #22987 27th Jan 2010 5:05am
CapeLandy
South Africa
I think the chap starting the topic will send step by step instructions if you don't know where the wire is.
P.S
I see the two of us are living in a republic now Cool
I thought we were the "last outpost" or the "top deck of the Titanic "Very Happy
Post #22988 27th Jan 2010 5:21am
Naks
Ah. Yes, I see Smile
yes, the Cape is a totally different country to the rest of SA. I realised this when I moved from Joburg 2 yrs ago!
Post #22989 27th Jan 2010 5:40am
A tip that mught be of use to to others....
My remote had a very limited operating range of perhaps one metre. I did the mod to extend the aerial and it made virtually no difference. Although there were no visual symptoms of the battery in the handset being flat, I changed it and the result is spectacular - the locking now works from about 50 metres away.
It eventually dawned on me that both handsets must still have the original batteries in them (the Puma is 3 1/2 years old) and clearly they were flat enough to be fairly useless, but not flat enough to give the warning signs listed in the handbook.
So if you still have no range, try a new handset battery.
Post #46400 26th Nov 2010 2:56pm
alantd
The dallier is supposed to change them at the 24m service. However, I wouldn't be surprised if they didn't - how many customers would know?
I'm going to take both sets in (although only one gets used) and get em both changed next month. One that started out as a 2.4 TDCi 110 XS
Post #46485 27th Nov 2010 1:29pm
Are instructions for this mod still available - my MY13 appears to have the same issue that the remote will not work from certain angles and others from only a foot or two away.
Post #242702 11th Jun 2013 7:59am
landybehr
Hi there,
I wonder if this modification can lead to the unwanted effect of increased sensitivity to interference.
Anyone noticed problems with the alarm/security-system/immobilizer since?
Post #242871 11th Jun 2013 8:54pm
K9F
^^^Not me in the three and a half years since embodiment. One of the best mods going and costs you nowt! 10 minute fit, if you're not happy I'll eat the spare wheel off my Landy and you can take the mod out in about 5 minutes.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #242875 11th Jun 2013 9:13pm
landybehr
K9F wrote:
if you're not happy I'll eat the spare wheel off my Landy and you can take t...:
:big-grin:
should I serve you ketchup to the spare wheel ?
My 2.2 came from Solihull with a r/c range that is ok. Some days ago I wanted to demonstrate the trick of touching my face with the fob to increase the range (think it was mentioned in this thread before) but I parked where there was nowhere to go further away than 20m - an in this range the standard system worked.
OTOH I´m not overly sure that an extended range would help me much. ´See -- I climb out of the Defender shut the door, then, with the key still in my hand press the knob, before the key is stored in the pocket. It was on two occasions in half a years time that I was at the house door, wondering if I have closed the car and from there (10m away) used the long-range-capability.
To be honest, after I parked in a forest (there is a radar/TV-sender nearby I think) and could not lock the Defender by the r/c-control (but fortunately could lock it with the key and it started) I was thinking the other way round in lowering the sensitivity of the system. But I´m glad there is no need to - after reading your post (for which I Thank you).
Post #242968 12th Jun 2013 1:36pm
Gareth
Does this mod also apply to the TD5? 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
1968 S2a 88 aka Bob
2014 Jaaaag F Type 3.0 Supercharged.
Post #242975 12th Jun 2013 2:05pm
mk1collector
Yes Thumbs Up
Post #242980 12th Jun 2013 2:44pm
bump - can anyone point me in the right direction please?
Post #243164 13th Jun 2013 7:43am
DAZ110
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Barolo Black
How to extend the range is near the start of this post.(Page 1)
Post #243171 13th Jun 2013 8:12am
Johnnyb0
Can I have the start bit please? Thanks. Johnnyb0
Post #250976 12th Jul 2013 8:56pm
